Exhaust Wrap - Insulator or Cooler?
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- notaduc
- Thank you received: 3
Many header manufacturers warranties are voided by the use of wrap, as the heat helps deteriorate the metal, stainless or otherwise.
Id stay away.
1980 (mostly) KZ1000
- 750steve
mark1122 wrote: here is a quote from an exhaust wrap company.
Premium Exhaust Wrap Details
Exhaust wraps help to retain heat in your exhaust system, which increases horsepower while reducing radiant heat damage. By wrapping the exhaust system it maintains hotter exhaust gases, decreases the density, and allows the exhaust gas to exit the system faster! Greater exhaust scavenging is produced and lowers intake temperatures: that equals more horsepower.
Mark, thanks for the post but i think when reading into that statement the mfr is talking about application on a car. It mentions lower intake temperatures which makes more sense in a car than a bike as the air under the bonnet would be cooler with tha headers wrapped.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Thank you received: 2829
I don't really care if anyone wraps their pipes or not, as long as they don't wrap mine, but I do challenge the vendor making that statement to provide an unbiased, third party, credible dyno comparison of a bike's HP rating before and after a pipe wrap with no other mods. I say it just ain't so or every manufacturer in the HP wars (Suzuki, Kaw, etc.) would be wrapping the pipes on their sport bikes and every race bike would have wrapped pipes. Again, not trying to start a war; I like my pipes chrome; others like black; others like wrapped - and that's cool or all bikes would be identical. I'm just saying the vendor's HP statement is meaningless without independent proof. Ed
- bountyhunter
- Thank you received: 337
It's because it traps condensation under the wrap which is never good with steel.notaduc wrote: Yea, heat wrap looks cool, but will likely muck things up.
Id stay away.
- bountyhunter
That should be a conditional statement, not an absolute. It MIGHT increase horsepower, assuming the entire system is retuned to the increased exhaust flow rate. It might not. Bike engines are so finely tuned on intake and exhaust that changing one knob without any other change usually causes a LOSS of horsepower.mark1122 wrote: here is a quote from an exhaust wrap company.
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- jeffasaki
- Thank you received: 44
higher temp may create a scavenge effect
I THINK it would be a better scavenge
without wrap though
SOME of these pipes have already been designed to run in a certain temp range
i would also woory about overheating the exhaust valvejust my 8 1/2 cents worth
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- bountyhunter
Not really. In fact, Kawi went to hotter plugs (B6ES) on the twins because they run so much cooler the cold B8ES plugs used in the fours would foul out in the twins.750steve wrote: Comparitively do these Twins run hot anyway Bountyhunter?.
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Thank you received: 2098
750steve wrote: B8ES is bad? Thats what came in my bike when i bought it! Maybe thats to do with the climate over here?........or should i change em to B6ES?
Would heed the FSM.
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
