Clutch problems 1979 kz750 twin
  • Pop147
  • Pop147's Avatar Topic Author
05 Jan 2012 15:53
#496521
When i pull in the clutch the bike still stays in gear. I can go through all the gears but, when im in gear and pull in the clutch it stays in gear. I adjusted the clutch per the service manual and it still did not let me roll around in gear with the clutch in. This bike in a project and i haven't heard it run yet, it has no oil in it and im waiting to get a battery to test for spark.
  • steell
  • steell's Avatar
Re: Clutch problems 1979 kz750 twin
05 Jan 2012 17:56
#496537
Probably just the clutch plates stuck together because it's been sitting for awhile.
Very common.
When you get it running, start it up and put it in first gear while holding the clutch in and the front brake applied.
05 Jan 2012 18:53
#496549
Also, you can try this....with the engine shut off - put the bike in gear; pull in the clutch; and rock the bike forward and backward. This will take some effort, but the clutch plates will free up. I had to go through this drill every morning with my old BSA because it had a competition engine with racing clutch plates made of aluminum that would stick like crazy. Once you get yours freed up and get oil in there you should be ok. Ed
  • Pop147
05 Jan 2012 19:50
#496562
Ill give it a try, then i guess its on to the stuck throttle. haha Ill try and get this into the project forum tonight with some pictures if i make some head way with the bike.
Thank you for the help
