engine oil leak / noob questions
- TheFlyingFreemole
30 Dec 2011 21:42
Just a couple of days ago I picked up a 1977 KZ1000 LTD. It had 20K original miles on the bike, and under 500 miles on a rebuilt engine. The engine rebuild was because the bike had sat for 15 years. Family owned for the last 25. Bike looked to be in great shape. When I bought the bike it hadn't been started in a couple of months but it fired up after just a few tries. Ran great. Took it home and parked it in the garage. The next day I noticed that there was a small amount of oil on the ground. It is engine oil and it leaks on the drivers (port? haha. left) side from just in front of the shifter. So I cleaned up the area and am now waiting in hopes of being able to trace the oil source.
While I wait...
If the previous owner had too much engine oil in the bike would that cause higher pressure and result in a leak/overflow somewhere? What areas should I try to examine for common leaks?
The bike has a oil window for checking level. How long does the bike need to run/how warm should the bike be before I try to take a reading? Bike on or off?
I have a clymer manual but haven't been able to find help for troubleshooting a leak
While I wait...
1977 KZ1000 LTD B1 (needs minor fine tuning)
- bountyhunter
Re: engine oil leak / noob questions
30 Dec 2011 21:51
Could be the output shaft seal is seeping oil. You need to clean it up really well and eyeball it to see where it's cming from. I don't think its from over filling the oil. Just hold the bike level after oil has drained down to check sight glass level.
- TheFlyingFreemole
30 Dec 2011 22:49
so i just went out to look for oil. I couldn't see any new leaks but the light wasn't very good. I rolled the bike forward about a foot to get a better view and in the process the bike spat out about a shot or two of gas. Not sure where this came from but seems to be the same general area. I don't know if the gas and oil spills are related or would come from a common problem maybe
- dbsuperbiker
30 Dec 2011 23:05
Older bikes sometimes accumulate flung chain grease on the left just in front of front sprocket. When heated up or diluted with gasoline it will drool down.
make a commitment to wash under the engine with mineral spirits or such, at least in the suspect area. Then inspect it in good light...it could be one of several things, too tough to guess.
- gwolever
31 Dec 2011 00:20
Does the oil look like it is actually dripping from the base of the shifter? I had that on my bike when I first bought it too. It was oil leaking from the stator cover. There is a spot just under the stator cover where some wires come out that have a rubber seal that is known to leak sometimes.
The guys at Klemme Performance who specialize in KZ's told me that while I was rebuilding the engine on my 82 to clean, polish, perform upgrades, install new gaskets, etc., that I could use some gasket sealant in that spot to help prevent it from leaking in the future.
Not sure if this is your problem, but just thought I'd try to throw an option out there for ya.
Good Luck.
Good Luck.
1982 KZ1000 CSR
31 Dec 2011 00:23
Besides possibilities already mentioned:
This grommet might be leaking:
Click > www.z1enterprises.com/detail.aspx?ID=373
Gasoline may drizzle from carb overflow tube(s).
- gwolever
31 Dec 2011 13:38Patton wrote: Besides possibilities already mentioned:
This is the rubber seal/grommet that was leaking on my bike. I didn't buy a new one cuz it was a pain in the ass to try and detach the wires from the inside of the stator cover (the screws would not budge, even with an impact driver) and I didn't want to try and cut and resolder. So I used some high temp gasket sealant there instead. No leak.
You might have better luck (with the screws/wires) though and could benefit from just replacing the grommet altogether.
1982 KZ1000 CSR
- TheFlyingFreemole
31 Dec 2011 15:58
hey thanks so far guys.
I sloshed the fluids side to side and noticed that more gas came out of the overflow tubes bundled at the the bottom of the bike. I found on the forum that this could be caused by the petcock... so I turned the petcock to the off position. Hopefully that does it.
Then while trying to find the oil leak I found that the furthest left carb has a hose that has a small slit in it and that gas will flow out of the hose if moved/wiggled. I'm going to have to replace that hose for sure...
I am getting closer to the oil leak source. At first it seamed like it was coming from this frayed chord.
But I think that the hose/chord is just the route the oil is taking to hit the ground... and it is coming from an area closer to the two spots in the last picture. The front spot is where 2 carb overflow hoses cross, and the other spot was from the bottom of the black cover. Not sure if this helps find the source
Attachment leakinghose.jpg not found
Attachment frayed.jpg not found
Attachment upperoil.jpeg not found
31 Dec 2011 16:19
I bet the last picture has the answer. It looks like one or more of the carbs are over flowing a bit. The fuel then runs down the back of the engine where it picks up goo (technical term, that) that combined looks like oil on the floor.
Turning the petcock off after each ride is a good idea, but there should be no leak even with it on. That leak suggests a needle valve or two are not doing their job.
- TheFlyingFreemole
31 Dec 2011 16:28 - 31 Dec 2011 16:52
When I look at the leak it looks definitely like engine oil not just gunk that is being washed down. The reason I say this is that the fluid is clean amber color and smells of engine oil. Doesn't look like gassed down grease or anything like that
EDIT: who am i to shoot somebody down attempting to help... i'm a noob. i've owned a bike for a week. i am going to be optimistic and hope that indeed the fuel leak is the causing gunk to drip.
Last edit: 31 Dec 2011 16:52 by TheFlyingFreemole. Reason: humility
- KraZyRIDER
31 Dec 2011 20:15
TexasKX has a good point. From the looks of the varnish buildup on the carbs, it appears the carbs have been leaking/overflowing for a while. The carbs and gas tank can build up with varnish from gas sitting and going bad after a long period of time. This can cause problems with the needles and seats and carbs in general and end up plugging fuel and air passages. If a needle, or needles are not seating properly, the bowls will overfill while sitting and drain through the vent/overflow tubes. That's what those hoses underneath the bowls are connected to. The only time those hoses should have gas in them is when one, or more of the bowls is overflowing and dumping fuel. Which they're not supposed to do. The suggestion to shut the fuel petcock off after a ride is also a good one. It will prevent the possibility of carb flooding due to a bad needle and seat.
If I were you, I'd drop the bowls and carefully spray the exposed area with carb cleaner. Make sure to turn the petcock off, or you'll have gas all over the place. If there's any varnish build-up or sediment causing the needles to not seat properly, you should be able to remove it with the carb cleaner. Spray down the outside of the carbs, as well. That will remove the hideous varnish stains on them. Just be careful not to bang into the hanging floats. Damage them and you'll have a whole new set of problems on your hands.
Was there fresh gas in this bike? If you're not sure, you might want to dump it and start with fresh gas. Not such an easy thing to do with gas being the price it is today, but it would be better for the bike if you don't know.
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
- TheFlyingFreemole
01 Jan 2012 01:01
So ever since the petcock has been turned off the gas/oil leak has completely ceased. The bike was 'run dry' of gas and had been sitting for approx. 2 months since last running. The bike needed to be put on reserve to start up. I added about a gallon of high octane to the tank and then noticed the leak.
So I got a hold of an old biker friend and am going to get a hand looking at the carbs/floats in a couple days.
If the floats were working correctly then it wouldn't leak fuel from the carb overflow tubes right? Is there any other reason that there would be fuel leaking through the carb overflow tube?
