Mac headers for 83 KZ440
- Jajao555
29 Dec 2011 09:56
My headers were pitted really bad so I got new headers and mufflers from Mac. I'm having a problem fitting them though. The Mac pipes have a different clamp and the spacers that hold the pipe in the port are too big. Here are a few pics.
You can see my new exhaust gasket the ring clamp and the 2 half circle spacers. The header has a different mount attached to it than stock.
Exhaust port
Original setup
The header is too wide for the spacers to fit in I'm thinking I can just use some other material instead I don't know what though.
I'm also having a problem fitting the circle clamp on because without I would have to cut the end of the pipe. I'd rather put a longer stud in.
What do you guys think of this?
Exhaust port
Original setup
Re: Mac headers for 83 KZ440
29 Dec 2011 10:38 - 29 Dec 2011 10:42Jajao555 wrote: My headers were pitted really bad so I got new headers and mufflers from Mac. I'm having a problem fitting them though. The Mac pipes have a different clamp and the spacers that hold the pipe in the port are too big. Here are a few pics.
Exhaust port
Original setup
Did Mac furnish installation instructions with the new exhaust system specifically identified for 1983 KZ440?
Is outside diameter of Mac header pipe different than o.d. of stock pipes?
Does inside curvature of half circle spacers conform to outside curvature of Mac header pipes?
Were new half circle spacers not furnished along with the new exhaust system?
Was there nothing in instatllation instructions about needing to modify the existing half circle spacers?
The sunburst clamp appears unnecessary in the new system.
Maybe the half circle spacers are also unnecessary in the new system.
Are the Mac clamps permanently affixed in position on the header pipes? Or do they move back and forth like the original sunburst clamps?
Perhaps the Mac system is designed to bolt on with only the new gasket, and without any old parts.
Last edit: 29 Dec 2011 10:42 by Patton.
- Nebr_Rex
29 Dec 2011 11:26
Yes,Mac does not use the Sunburst.
And new spacers from Mac are a different length than stock,at least they where on the pipe I bought new for a KZ650.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- steell
29 Dec 2011 14:49
Mac pipes don't use the sunbursts (stock collars) or the spacers on the KZ twins, the flange is welded to the pipe and bolts to the motor using the stock studs.
Usually you have to spread the pipes a little to get them on.
- Jajao555
31 Dec 2011 10:43
I got them on I just put the gasket in and tightened them without the the spacers and stock collar everything fit pretty good. I haven't started it yet so I'll have to see if I can find any leaks and I'll post some pics up.
Thanks guys.
Thanks guys.
- DSchneid
21 Aug 2017 20:46
Just a shot in the dark as this is an old Post. Any luck with the exhaust? I'm having the same issue and wanted to know if you are getting any exhaust leak.
- 80kzer
05 Jun 2020 15:40
I'm having the same problem as well. The inside has 1 inch of space to the gasket and the new Mac 2 to 1 is an 1 5/8? How is that suppose to fit without a spacer or that starburst piece?
