oil cooler hook up
  • kool4kawis
  • kool4kawis's Avatar Topic Author
  • live is just evil in the mirror
oil cooler hook up
28 Dec 2011 20:07
#495018
can I just remove the plug in the oil pressure unit, replace it with an -AN fitting and use that to feed the oil cooler. Thanks guys.
  • TexasKZ
  • TexasKZ's Avatar
Re: oil cooler hook up
28 Dec 2011 20:13
#495019
What is your plan for the return line?
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
28 Dec 2011 20:40
#495025
no, u have to buy fittings for both feed and return
  • kool4kawis
29 Dec 2011 00:23
#495077
I planned to drill and tap the oil pan
29 Dec 2011 02:16
#495092
kool4kawis wrote: can I just remove the plug in the oil pressure unit, replace it with an -AN fitting and use that to feed the oil cooler. Thanks guys.
:unsure: What year, make and model?
  • Old Man Rock
  • Old Man Rock's Avatar
29 Dec 2011 10:34 - 29 Dec 2011 10:43
#495114
Drill & Tap your Oil Pan????
These would work better for ya.... ;)
KZ-650 Oil Cooler Engine Adapters
OMR
EDIT: I've downloaded this file to the Filebase here for future references... Basically goes through the installation procedure for you KZ650 folks.
kz650-oil-cooler-adapters-installation
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 29 Dec 2011 10:43 by Old Man Rock.
  • Kawickrice
  • Kawickrice's Avatar
30 Dec 2011 18:16
#495331
Does the bike run hot? You want some heat in the engine. Running it to cool will do more harm than good in my opinion. Plus on cold starts it takes awhile for the oil to get to the motor because the oil will drain to the pan when not running leaving air in the lines instead of oil. I live in Florida and run one on my Z1 but not on my GS1100 or my KZ650. In the winter I disconnect my cooler on my Z1 if I am doing ant cool weather riding. In very hot weather or a hot rod motor is where you see a benefit from a cooler.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • bountyhunter
  • bountyhunter's Avatar
30 Dec 2011 21:44
#495368
Yes, that's how a "parallel" cooler hooks up but you have to have a restrictor orifice at the point where the oil comes out so there is minimal pump pressure loss. Also need a thermostat in series to prevent oil flow throgh the cooler until the oil gets hot.
  • bountyhunter
30 Dec 2011 21:46
#495369
Kawickrice wrote: Does the bike run hot? You want some heat in the engine. Running it too cool will do more harm than good in my opinion.
That's true.
