Front sprocket for a 81 csr
  • kool4kawis
  • kool4kawis's Avatar Topic Author
  • live is just evil in the mirror
28 Dec 2011 20:05
#495017
I have an 81 csr motor and am going to run a 180-200 rear tire. I've been told that a 5/8 offset sprocket is what I need for clearance. So here is my question, do I need 5/8 more than stock or 5/8 total. I need to know because it is a custom job and I dont want to order the wrong one. Thanks for all the help.
  • TexasKZ
  • TexasKZ's Avatar
Re: Front sprocket for a 81 csr
28 Dec 2011 20:17
#495020
I don't think there is an offset to the stock sprocket, so the answer would be yes, either way. You know you can buy them, right?
This is assuming that this is for a CSR 1000.
  • kool4kawis
29 Dec 2011 00:27
#495078
Haven't been able to find one in 520 or 525 pitch. I need to match it up to a 04 zx 636 rear sprocket. I talked to a guy on Ebay and he said he could make one no problem but I want to make sure I'm giving him the correct info before I order it.
