Please help!!!!
- dylan_kz750
Please help!!!!
16 Dec 2011 22:45
I recently bought a 82 KZ750 LTD. Got a good deal, or so I thought. Bike ran when I went a looked at it, but ran a little rough(still ran enough for me to get around on though). I knew the bike was old and probably needed a carb clean, so I put that on the list. I rode it around for a few days, never anything longer than maybe 20 minutes or so. I started noticing it losing power and seeming to choke out a little bit when I was getting to the end of my short rides. I didn't die out at first, but then it started dying out quicker and quicker(all this over about 5 days or so. It got to the point where I can't have it running for over 5-10 minutes or so before it starts to lose power and die out. I can't get it to start again for another 15 minutes or so after that and it does the same thing. Its just crazy how fast it went from riding ok to not riding at all. Very frustrating. So far I've:
Changed fuel lines and filters
Removed petcock to look for anything wrong
Changed oil(when I changed it, the old oil smelled of gasoline)
Cleaned Carbs
Treated with Seafoam
It's not much, but I am a DIY beginner. Second bike, but its older so I knew I would have to learn it.
I've been told it could be the valves needing adjusting, which I plan on checking, but I've also been told that if it were the valves I would have trouble getting it started, which I don't unless its been running for a while. It cold starts great.
I've also been told it could be the rings, but people have also said that if it were the rings then there would probably be white smoke coming from the exhaust.
Any help would be appreciated greatly. I know these beginner posts can be annoying, but its all I got! Thanks in advance.
Cleaned Carbs
- etbike3135
Re: Please help!!!!
16 Dec 2011 23:08
Is there any popping or backfiring when it begins to slow?
Does it still idle well when this happens?
Does the bike have stock exhaust and is the airbox on the bike?
1973 Kawasaki Z1
18 years in dragbikes
- lemo32
- The Price of Cool aint cheap
Re: Please help!!!!
16 Dec 2011 23:13
When you get a bike, your first bike, people tell you anything. It could be this it could be that, take the time to treat each system seperate, as its own entity. Meaning start with one system and follow through, For instance,check compression, ok? move on to valve adjustment, ok? move onto fuel, then wiring, make a list if you have to, Its a process of elimanation, running sea foam through carbs is not carb cleaning? if you dont understand these processes then read and learn, if you dont want to learn then take your bike to a shop and pay somebody to do the work, you will be happier in the long run.
1979 kz 1000 06 katana 750
- KZJOE900
- Administrator
Super Users
Re: Please help!!!!
16 Dec 2011 23:38 - 16 Dec 2011 23:40
Possibly you may have venting issue with your tank cap. The bike sounds like it may be starving of fuel. Once the pressure equalizes after 15 min, the fuel starts flowing and the bike starts again. Might try riding it with the gas cap not completely closed. As for the smell of gas in your oil, you may have a petcock issue letting gas flow in the off position. Sounds strange on the one had that you can have not enough fuel and on the other an over flow. But once it sits and pressure equalizes you may be getting unintentional fuel going into the floats. And if there is an issue with one of your float valve needle/overflow tubes, you will get fuel in the crank.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 16 Dec 2011 23:40 by KZJOE900.
- KZQ
- Administrator
Re: Please help!!!!
16 Dec 2011 23:43
Hi Dylan,
Get on the bike, pop open the gas tank and go for a ride. Course only a fool would ride a motorcycle with an open gas tank so you should find another way to check to see if the air vent in the gas cap is capable of admitting air as the fuel drains.
Your symptom sounds like fuel starvation.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- LarryC
Re: Please help!!!!
17 Dec 2011 00:08KZJOE900 wrote: Possibly you may have venting issue with your tank cap. The bike sounds like it may be starving of fuel. Once the pressure equalizes after 15 min, the fuel starts flowing and the bike starts again. Might try riding it with the gas cap not completely closed. As for the smell of gas in your oil, you may have a petcock issue letting gas flow in the off position. Sounds strange on the one had that you can have not enough fuel and on the other an over flow. But once it sits and pressure equalizes you may be getting unintentional fuel going into the floats. And if there is an issue with one of your float valve needle/overflow tubes, you will get fuel in the crank.
Good Advice!
If that doesn't do it, get a compression gauge and check compression on all 4 cylinders cold and then hot. Post what you get for numbers.
Those 750's used to get the tar beat out of them and the valves can tighten up. A valve clearance check is certainly something you'll want to do to it. Point the cam lobe directly away from the bucket and check the clearance between the base circle of the cam and the bucket. Do each lobe, one at a time that way.
Most feeler gauges you buy at an auto parts store only go down to .004". But Sears should have a set that goes down to .0015". If, on any of the valves you cannot get the .0015" feeler to go in, see if you can spin the bucket with your finger. That all should be done on a cold engine.
Larry C.
- dylan_kz750
Re: Please help!!!!
17 Dec 2011 18:10
Soooooo, I took the advice with the gas tank open, but I also moved the petcock into free flow rather than on(when on the fuel only runs through with the bike on supposedly), it started right up, warmed up and I rode it for an hour only to shut the bike off myself, rather than it dying out on me. So, good news there! Now the battery is dead and I think it may have to do with one of the spark plug wires breaking off in my hand and me putting it back together temporarily. Is this a common cause of dead battery? bad connections within spark plugs? The battery is fairly new, but I had autozone charge it with a trickle charger(that's what they said) and I'm afraid they've screwed my battery. Any thoughts? Thanks so much to everyone else's advice. For the bike running the way it did today, its a big step in this project. Thanks again...
Sincerely,
Newbie
Sincerely,
Newbie
- MFolks
Re: Please help!!!!
17 Dec 2011 18:35
Get yourself a motorcyce rated trickle charger. I've been using one called "Battery Tender" for years. Motorcycle batteries should not(In my opinion) be charged at more than 1.25 amps an hour, as anything higher may boil the fluid and possibly warp the plates.
batterytender.com/
smartercharger.com/battery-chargers/
batterytender.com/
- MFolks
Re: Please help!!!!
17 Dec 2011 18:42
Most Kawasaki's take 7mm sparkplug wires, unfortunately, some of them have the sparklug wires molded into the ignition coils. To see if your's are replaceable,look for removable caps with ridges on the coils where he sparkplug wires come out of.
If they have ridges, turn them to the left to remove the sparkplug wires. Be careful in not loosing the rubber seals, & small plastic cones making for a water tight connection. Rubbing Alcohol makes for a good lubricant when re-assembling the wires(sparkplug high tension leads know in some areas).
- dylan_kz750
Re: Please help!!!!
17 Dec 2011 20:11
would that have anything to do with the battery being dead? Spark plugs, wires, and/or connections?
- KZJOE900
- Administrator
Super Users
Re: Please help!!!!
17 Dec 2011 20:30The spark plug wires have nothing to do with the battery going dead. As for the issues with the wires, only age (live span) would cause to become brittle and crack and leak spark. Unless they are new and were defective to begin with.dylan_kz750 wrote: Now the battery is dead and I think it may have to do with one of the spark plug wires breaking off in my hand and me putting it back together temporarily. Is this a common cause of dead battery? bad connections within spark plugs? The battery is fairly new, but I had autozone charge it with a trickle charger(that's what they said) and I'm afraid they've screwed my battery. Any thoughts? Thanks so much to everyone else's advice. For the bike running the way it did today, its a big step in this project. Thanks again...
Do you mean the cap came off the wire? Some caps screw into the wire and it could have came off. Is that what you mean. Just cut a small piece from the wire and screw the cap back in. As long as the wire looks to be in good shape. If that is what happened.one of the spark plug wires breaking off in my hand and me putting it back together temporarily
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
