Jets?
- dizl27
16 Dec 2011 01:26 #493332
by dizl27
1977 650 Hardtail Bobber
1996 250 Yamaha Virago Bobber
Jets? was created by dizl27
So i just got my carbs apart to clean out. Im just curious how to check my jets and what size im supposed to be running. I live in southern california so i figure i might have what im supposed to be running. What is the size guys? I will be running straight pipe but i might put a baffle in to clean up the sound.
- dizl27
11 Apr 2012 08:13 #515205
by dizl27
Replied by dizl27 on topic Jets?
So i am still at it. I had the engine running when my exhaust ran 4 pipes into 2. Now that i have changed to straight 4 pipes it has not ran since. I am thinking i need to jet up but carburation has been my weak side of this build. Any suggestions to what sizes. I am also running pods. I have mk carbs not sure exactly what type. Pod opening is 1.5 inches. I ordered previously in a metric size but have know forgotten that size. All help is appreciated.
- Old Man Rock
- Thank you received: 225
11 Apr 2012 10:52 - 11 Apr 2012 10:56 #515220
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Jets?
NOTE: Assuming timing, valve clearances, electrical/ignition timing is to spec....
Manuals:
VM Carb Re-build Tuning
VM Manual
For KZ900/1000 OEM Jettings, may be similar or same.
Manuals:
VM Manual
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 Apr 2012 10:56 by Old Man Rock.
- gd4now
- Denco where did you go?
- Thank you received: 440
11 Apr 2012 13:19 #515243
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Jets?
Those appear to be VM24ss Carbs. With the pods and straight pipes I would think a good starting point would be as follows;
Pilot jet 17.5
Main jet 110 or 112.5 - may need larger with open pipes
Depending upon which needle is in the bike set to either the 3rd or 4th slot
for the 5DL31 - set it to the 3rd slot
all others on the 4th slot
Pilot jet 17.5
1977 KZ650 B1
- dizl27
11 Apr 2012 18:46 #515291
by dizl27
Where do I pick up these larger jet kits?
- cameronkawasaki
- Thank you received: 1
11 Apr 2012 19:10 #515296
by cameronkawasaki
1979 KZ750B-4
Replied by cameronkawasaki on topic Jets?
For the new jets take a look at motorcyclecarbs.com
They have a lot of jets for our old bikes.
1979 KZ750B-4
- gd4now
11 Apr 2012 21:24 #515308
by gd4now
1977 KZ650 B1
There are many locations to get them from - you might want to look at the vendor menu on this site.
You could also try any of these - keep in mind I have not visited all of these site recently so do not know what the do and do not have currently. I am sure there are others, this list is just what I have handy to pass on.
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.oldbikebarn.com/Motorcycle_Parts/Carb-Rebuild-Kit
www.cycleorings.com/
www.z1enterprises.com/
www.sudco.com
www.nrp-carbs.com
www.carbparts.com
www.jetsrus.com
www.sudco.com
1977 KZ650 B1
