KZ 1000 Mk II pumpers
  • Veazey
  • Veazey's Avatar Topic Author
13 Dec 2011 07:50
#492908
I found a set of KZ 1000 MkII pumpers that I want to purchase. I noticed that they have dual fuel feeds as opposed to my one. Can these be used on my KZ 650, and if so could someone tell me how? Also can someone tell me if I put these carbs on right away before doing the top end with the Wiseco pistons and megacycle cams will the bike still run or would that be overcarbureted for a stock KZ 650. Can't afford all of the performance mods yet, but would really like to get these carbs.
  • LarryC
  • LarryC's Avatar
Re: KZ 1000 Mk II pumpers
13 Dec 2011 08:11
#492909
You can pick up a Y fitting for the fuel lines. Get a good metal one, brass or aluminum. You have to swap to kz 1000 manifolds as well. The port runners should be matched up to the new manifolds as well. IMO, you're better off waiting until you have it apart for the rest of the build.
Someone on here should have jetting specs for you. They'll require some tuning.
Larry C.
  • RonKZ650
  • RonKZ650's Avatar
13 Dec 2011 12:06
#492926
KZ1000 MKII carbs were single fuel inlet, so something wrong with those carbs. Also KZ1000ST pumpers were single. So whatever they are they are not 100% original. Yes you can Y off the fuel line to use them on a KZ650 but they won't fit on the stock KZ650 inlet rubbers and also won't work with the stock KZ650 airbox rubbers or KZ650 pods.
  • Veazey
13 Dec 2011 14:35
#492952
Ok, thanks. I forgot about the pods. I'll ask this guy whats up with the fuel inlets. I appreciate the info.
  • LarryC
  • LarryC's Avatar
13 Dec 2011 16:09 - 13 Dec 2011 17:09
#492960
1980 ltd had dual feed, pumper 28's. KZ1000LTDB4
Larry C.
Last edit: 13 Dec 2011 17:09 by LarryC.
  • RonKZ650
  • RonKZ650's Avatar
13 Dec 2011 23:53
#493034
LarryC wrote: 1980 ltd had dual feed, pumper 28's. KZ1000LTDB4
That's what they are, or 1979 KZ1000 LTD carbs which were 26mm I believe. There are gazillion LTD parts out there compared to ST or MKII.
  • LarryC
  • LarryC's Avatar
14 Dec 2011 00:22
#493042
Yep...79's had 26's with pumps. 80's got the 28's ;) Manual petcock on those bikes so they got the duel feed lines on the carbs. Everything else had the vacuum petcocks and got the single feed line.
Larry C.
