- Thank you received: 1
KZ1100 HEAD ON KZ1000J
- kz1100warrior
- mtbspeedfreak
- Thank you received: 36
The first example is simply a big bore Z1 900. This engine came with a kick starter and electric starter. The cam chain tensioner hole in the cylinder block is a rectangle. The ccs cast on the cylinder is 1015. The later "J model" has no kick starter, and the cam chain tensioner hole in the cylinder block is round. The cc's cast on the cylinder is 998. This engine also became the GPZ1100 in 1981 and '82, and virtually everything between them is the same. (The '83-'84 GPZ1100 was changed). Cylinder blocks and lower engine cases are NOT interchangeable. You can not put a J model cylinder on an older style lower end, and vise versa.
www.aperaceparts.com/tech/techkz1000.html
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
2000 ZRX 1100
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Mookachacka
- Thank you received: 4
kz1100warrior wrote: Please can someone inform me, can you put a KZ1100 head directly onto a KZ1000J cyclinder with out changing much, valves etc ....Head is a KZ1100 A1 and the bottom is a KZ1000J.
I would rather put the KZ1100 cylinder block on the KZ1000 J motor, going from 998 cm3 to 1089cm3.
- otakar
x2
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Ditto + a nicely ported head with some 410 cams and... whoops there goes my inheritance lol.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
- kz1100warrior
- Kitten Tooth
- Thank you received: 10
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- TeK9iNe
Kitten Tooth wrote: id love to put a J head on an 80 and down 1000/900 cause of the kickstarter. So many rides where i had to push 600 pounds of iron up the street just to get going when my starter took a dump
:laugh: :laugh: :laugh: Fix it right the first time... kidding.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- lucienmaier
Want to swap a bad jug for a 84 gpz1100 jug with pistons
is that doable?
--1981 Kz1000m CSR--
--Converted to 1100CC---
