PLEASE HELP.....TIMING OUT??! (video)
- gumby prichard
Re: PLEASE HELP.....TIMING OUT??! (video)
04 Dec 2011 17:30
motorhead, any insight on that float needle theory?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
04 Dec 2011 17:45Float needle theory?? Which thread was that??gumby prichard wrote: motorhead, any insight on that float needle theory?
point me to it please or refresh my failing memory.
- gumby prichard
04 Dec 2011 22:01
Earlier in this thread i said my mechanic friend switched my float needle because my old one was warn out, but he replaced it with a metal tip float needle instead of the oem rubber tip float needle. Thus possibly creating a seal not as great.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Topper
05 Dec 2011 08:40
I wouldn't think that could cause the problems you're describing. If your friend accidentally changed the float level in the process, that could explain some of your symptoms. Check the float levels with the clear tube method (should be in your manual).
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Motor Head
05 Dec 2011 10:05Topper wrote: I wouldn't think that could cause the problems you're describing. If your friend accidentally changed the float level in the process, that could explain some of your symptoms. Check the float levels with the clear tube method (should be in your manual).
Just like Topper said, check the fuel level in the float bowls with a piece of clear tubing hooked to your drain fitting, and petcock on Prime. You will be off more than likely with a new float needle valve, and need to bend the float Tang to adjust the fuel level.
- gumby prichard
06 Dec 2011 15:47
yes, i have checked the float levels many times. Thanks guys i shall continue the rest of my journey. lol. lately school has been holding me back.If i didn't have to spend all summer searching for piston rings i would have been good. Oh well.
:S
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
13 Dec 2011 06:27
OK so, the slow regressing rpms were due to the fact that my carb needles were replaced with metal tips rather then oem rubber tips! I ended up Messing a lot with my ignition timing, and as far as back firing, it didn't fix anything, so i checked my cam to crank timing and it ended up being correct, so i moved back to carburetor and or ignition timing troubleshooting. I ended up completely taking out the ignition timing plate...and checked the advance mechanism. I extended it and made sure it worked, i put the ignition plate back on and fiddled with the air/fuel mixture screws and the idle screw and now it idles great!
Now, when i give it gas it dies, I figured it was due to too large of a main jet, so i went from 100 to 92(i am running pod filters so i jetted up before.) and it was still dying when i gave it gas, so i went down one more to 90. It will still die occasionally when you hit the throttle too fast, but if you ease into the throttle it revs fine. I pulled the plugs and they also say it is still running too rich, so I guess i will be moving down to a 88 or 85 main jet. What doesnt make sense to me is that the stock main jet, with an airbox is 85.....so how could the jet size be the same using pod filters as it is using an airbox? My only guess would be maybe the new float needles has altered it.
I should probably sync my carbs.... any suggestions? is it easy to do????
Thanks guys.
Thanks guys.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
