PLEASE HELP.....TIMING OUT??! (video)
- gumby prichard
Re: PLEASE HELP.....TIMING OUT??! (video)
28 Nov 2011 00:56
i disassembled as far as my cylinders. when reassembling, i followed the manual as far as putting the cylinders on then the valves, and then put the camshaft in and made sure the pistons were at top dead center, then bolted down the cam chain sprocket to the chain wheel and finally made sure the camshaft lined up and bolted down the cam shaft.
in order to check this I'm guessing im going to have to disassemble the motor again, if there is any other way to do so than pulling the motor, please let me know.
also I'm not sure how to set the timing with a "strobe inductive pickup light"
ill google that part.
thanks for the help guys, greatly appreciated.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
28 Nov 2011 01:04
The Light is for the Ignition/ Spark timing. Inductive pick-up, that goes around the spark plug wire, to pick up the spark signal. Then the light flashes each time the plug sparks.
To verify the Camshaft to Crankshaft timing the valve cover would need to be removed, along with the side cover for the ignition pick-ups. You won't need to pull the motor out. Do you have a compression tester? If the compression is even but low, then that would point to possibly a timing issue with the Cam to Crank.
From the video, as short as it was, the motor sounded Ok. More like a Vacuum or Carb problem.
Put your Bike INFO in to your Profile Signature so everyone knows what you got. Then it will show up on every post.
The following user(s) said Thank You: gumby prichard
28 Nov 2011 12:09
Looks and sounds like classic lean mixture. Unless intake manifolds are new, they could very easily be leaking. With the engine running, spray some brake cleaner, carb cleaner or WD40 on the manifold to head junction (all the way around on all manifolds) and on the carb to manifold junctions. Any noticeable change in rpm indicates leaks. If there are visible cracks in the manifolds or if the carbs are not fully seated in them, there will be leaks.
Unless every single itty bitty orifice in the low speed circuit of each carb is perfectly clear and clean, weird idle will occur.
In the carb rebuild, could the floats have been accidentally "adjusted"? Clear tube method (search forum or filebase) is best. If the fuel level is too low, weird idle and running will occur.
If the timing was ok before the teardown and none of the timing components were messed with, then the timing is likely ok now.
- gumby prichard
28 Nov 2011 21:56
Thank you guys very much. I do have a bolt that stripped on one side of one of my manifolds, but i didn't think it would effect it because it never did before. I rode it at least 100 miles and it never faltered before. I will also get one of these light ignition timing things.
motorhead, once the valve covers are off what should i check to know it's on time? or do you mean take off the whole top valve cover?
The thing i'm most worried about isn't the high idle at first though, it's the horrible backfiring once i take the choke off. It dies as soon as i give it gas, as if the mixture is too rich, but 100 to 92 is a big drop, and with the airbox, the stock jetting is 85 i believe. After checking the plugs it shows a rich mixture, but i think it's only because i must leave the choke on to get it to idle decently.....i went down from 100 to 92 jet size and both times plugs were black. I can't tell if the mixture is most likely too lean or too rich. Would replacing the piston rings alter the air to fuel mixture and require a re-jet? or should i just leave the 100 in there as it should be the same as my old rings?
i updated my profile, thanks again guys
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
28 Nov 2011 22:18
You would need to be able to see the cam chain, since you had the top of the motor apart. The Mark on the cam gear, and the mark for TDC at the Crankshaft. This should be shown in the book you used. One reason for checking the Ignition timing, is on the twin, your Ignition is run off of the Cam. So if the Cam to Crank Mechanical timing is out, then so is the Ignition timing. On the 4 cyl bikes the Ignition is run off of the crankshaft, so the spark timing won't change from a teardown, at least on the electronic stuff.
If you have a Striped bolt on the carb Intake manifold, fix that. Make sure those Manifolds are Sealed against the head. This is what the Bike sounds like, Vacuum leak.
Putting a new set of rings in the bike, won't change your jetting. Backfiring through the carbs= Lean, or Miss-timed Cam to Crank, maybe Ignition timing if its off enough.
- gumby prichard
28 Nov 2011 22:27
so glad we could narrow it down! Thank you sooooo much.
I'll check the both mechanical and electronic. In the mean time, any ideas on hove to remove that stripped bold i have stuck in the manifold. I'v tried to extract it twice, and the extractor ended up breaking off in the screw, so i attempted to just drill the whole thing out and re tap it, or just put a nut behind the manifold. In doing so the tap ended up breaking off in the newly drilled hole....basically it's a huge mess, bting that the tap is hardened steel, I'm out of ideas. one thing after another.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
28 Nov 2011 22:34 - 28 Nov 2011 22:51
Well you will have to get that mess out of the hole. Won't be easy with that hard metal broken in there. Make a trip to ACE Hardware and get a Left Hand Cobalt Drill bit, or maybe a couple. Try to keep the Center of the hole as you drill, if it will drill. You might be able to take a punch and sharpen it to an angle. Then use it to force a anti-clockwise rotation on the stuck Junk. In the end you will need to Heli-coil, or other thread insert repair. Or a stepped stud maybe. If you can drill it all out and get a nut on the end of a bolt, well that would do it I guess.
A Dremel tool with a Carbide Cutting bit might be you cheapest best bet for getting that mess out of the bolt hole. Harbor Freight has a cheap one, <$20. Their cheap one is on sale for $10.
This is the one I have; www.harborfreight.com/professional-4-spe...-tool-kit-40457.html
Last edit: 28 Nov 2011 22:51 by Motor Head.
- gumby prichard
28 Nov 2011 23:21
thanks so much. you rule. I'll let you know what i figure out.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
04 Dec 2011 03:27
HEY GUYS!
Somewhat exciting news. drilled out the old bolt and ended up just putting a bolt with a nut on the other side, to seal the carb boot/manifold leak. Anyway it reduced the backfiring a significant amount! it's running much stronger, but i am still getting the slowly reducing rpms when releasing throttle.
I completely disassembled the carbs and cleaned. In doing so i realized my mechanic friend replaced my old rubber tip float needles with metal tip float needles. I'm thinking this may be causing my rpm problem.....any thoughts on this theory? I also picked up the ignition timing light that MOTOR HEAD suggested from an antique shop! Plan on soon setting my ignition timing.....if all of this fails, I'm guessing it must have something to do with cam to crank timing........ we shall see. thank you guys so much again.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
04 Dec 2011 10:49
Now that you have your manifold bolted in place, take some spray brake cleaner and spray around those while the motor is at Idle. If you get an Increase in RPM then those are not yet sealed to the head. Or they may be cracked/ separating. This vacuum leak problem, could be your slow return to Idle. You can also check your throttle cable for sticking/ enough free play, etc.
Once you get the timing light hooked up you can check the timing at Idle and then at 4K RPM. That will be the Full amount of Advance, your Advancer has both marks for Idle and Full advance. Check to make sure it goes up and then down the range of advance smoothly.
- Topper
04 Dec 2011 11:07gumby prichard wrote: HEY GUYS!
So what did the trick on drilling out that old broken bolt? Was it a left handed bit or something else?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- gumby prichard
04 Dec 2011 17:29
the carbide dremel bit helped the most. I ended up buying a smaller titanium bit and drilling through the middle of the bolt, then took the tapered carbide dremel bit and widened the hole with that. eventually used my larger titanium drilling bit to bore out the hole......
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
