How I removed my engine
  • bluej58
  • bluej58's Avatar Topic Author
23 Nov 2011 18:18 - 23 Nov 2011 21:26
#489872
I borrowed a bike jack from a friend to get an idea for a comfortable height to make a work table.
But I found out that the engine got in the way, and that gave me an idea.
I have a bunch of hard wood laying around so I just started experimenting .
It came out pretty easy for just one guy, the big hang ups are the cam chain cover , exhaust studs ,
the lower engine mount by the kick starter and the lug for the oil filter.
I think I rotated it counter clockwise a little and tipped the jugs out to clear the cam chain
then lifted it to clear the filter lug and it fell out.
I highly recommend another person to hold the bike , add or move shims and help with the lifting,
and next time I will fasten stop blocks down to the board on ether side of the frame to keep it from moving around and straps are a good idea.
Another idea is to put the nuts on the exhaust studs to protect the threads and frame
JD
78 KZ1000 A2A
Last edit: 23 Nov 2011 21:26 by bluej58.
  • Kapahulu
  • Kapahulu's Avatar
Re: How I removed my engine
26 Nov 2011 12:49
#490207
Great idea!
2strokeworld.com
  • trianglelaguna
  • trianglelaguna's Avatar
26 Nov 2011 13:04
#490210
with the kick starter on...i can pull one myself,,,,,a smart helper with an eye for his/her fingers ...can give a tiny tug on the stator and it is free....you did well...it can be pulled straight away on the kick stand if all bolts or pulled this too
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Chaotic Reason
  • Chaotic Reason's Avatar
26 Nov 2011 22:29
#490273
That's an interesting way of doing it JD. Very creative.
I always like the "drain all the oil and then tip the bike over on a couple of tires" method. Unbolting everything is easy, and then lifting the frame off the engine is a breeze. ;) Of course then you do have to move the engine, but that's a possible topic for another thread.
Michael
1980 KZ1000 shaft drive
  • 750steve
  • 750steve's Avatar
27 Nov 2011 09:51 - 27 Nov 2011 09:51
#490314
I had to get mine out with the help of a friend, so there were 2 14 stone & 17 stone irish men at it! lol
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 27 Nov 2011 09:51 by 750steve.
  • bluej58
27 Nov 2011 12:50 - 27 Nov 2011 13:00
#490331
Thanks guys,
The last time I had the motor out was in 87 right before the trip in my avatar,
and we used the lay it on the tires method, from what I remember it when well.
I was going to wait for my son to come home from collage to pull it when this idea sprung up.
The bike has been moth balled since 92 because of three kids and a mortgage.
Now that we are empty nesters it's time to be a little selfish.
I tried to get her back on the road two years ago but the work / money wasn't readily available so all I did was get her fired up and spray down all the nuts and bolts with penetrating oil .
Finally it's time and I am enjoying the hell out of working on it.
JD
78 KZ1000 A2A
Last edit: 27 Nov 2011 13:00 by bluej58.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 Nov 2011 15:00
#490355
bluej58 wrote: Thanks guys,
JD
Awsome B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • wireman
  • wireman's Avatar
27 Nov 2011 15:09
#490359
i always remove the exhuast studs before yanking a motor out myself B)
  • fordtruck
  • fordtruck's Avatar
27 Nov 2011 15:22 - 27 Nov 2011 15:24
#490361
bluej58,
I look forward to reading about getting your bike back on the road. I too enjoy the heck out of working on mine!
'77 KZ1000-MTC 1075 kit. Stage 1 port
Last edit: 27 Nov 2011 15:24 by fordtruck.
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
01 Jan 2012 18:26
#495674
Im in Il to how soon will you be riding and what part of il are you from im over near st louis mo but I ride all over the middle of IL
84 kz 700 a1
82 kz550 ltd
  • Godfrey
  • Godfrey's Avatar
01 Jan 2012 19:37
#495700
I usually just use my floor jack, but then the 900s and 1000s are about 100 lbs heavier then my 750
1981 650CSR frame
1980 KZ750E engine
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
01 Jan 2012 21:53
#495738
I actually like working on them more than riding. What part of Illinois you from? I'm only bout 30 mins from Danville.
