KZ900-KZ750
  • flhwesty
  • flhwesty's Avatar Topic Author
KZ900-KZ750
21 May 2006 18:52
#48974
Will a header of of a 1983/84 KZ750 fit on a 1976KZ900A4. I can make it fit the frame but are the cylinders the same distance and are they the same diameter?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: KZ900-KZ750
21 May 2006 19:26
#48978
They are a diff diameter.
A 1000 (or possibly even an 1100) header will fit your 900 though.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • Mark Wing
  • Mark Wing's Avatar
Re: KZ900-KZ750
21 May 2006 21:29
#49011
besides the spacing it may be to short to fit under the motor. If it's tall enough you may be able to spread the tubes a little to make it fit.
Mark
Yorba Linda Cal.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: KZ900-KZ750
22 May 2006 05:43
#49058
Steve E pointed out that my response was mostly incompreshensible... head... header... I thought you had said.... ahhhh never mind, I am awake now!
The cylinder spacing for the cylinders is the same. The diameter of the exhuast ports are most likely not.
Post edited by: wiredgeorge, at: 2006/05/22 15:18
