The offending spring, nut and the solution
- primemover
20 May 2006 17:29
Hi All,
ok....
had GREAT luck today! Thanks....
after looking around at a few different things (and weighing all the GOOD advice/suggestions), the BELOW is what i came up with to get that nut off...
(see the pic below)
1) had the bike on the side stand and in gear
2) used the "clutch tool"(but first used a grinding stone to grind down the metal slats a little bit - they were a bit too wide to fit nicely within the spaces of the clutch) - had this tool ludge against the bolt of the foot peg as a "stress bearing member" - cable ties are there just to keep it from moving around; this is positioned at ~6 o'clock
3) based on advice from a guy at a cycle shop, i picked up 2 HUGE screw drivers and have them wedged in as well (they're at ~10 and 11 o'clock); i figured to keep them in place i would attach them (with hose clamps) to the bike's frame - again as "stress bearing members"
4) got myself a length of pipe as a "breaker bar"
I held my breath, said a little prayer (only kidding) and gave the pipe one good HEAVE!!
i heard/felt some movement!
did it again...
ZIP!
right off!
THANKS!!!
ok....
(see the pic below)
did it again...
ZIP!
right off!
THANKS!!!
- primemover
Re: The offending spring, nut and the solution
20 May 2006 19:58Please Log in or Create an account to join the conversation.
- primemover
20 May 2006 20:00Please Log in or Create an account to join the conversation.
