cam chain tensioner sprocket
  • gmannz1
  • gmannz1's Avatar Topic Author
06 Nov 2011 16:16
#487242
I have the head and barrels off my 1980 KZ750 LTD twin. I found the cam chain tensioner sprocket will turn, but not spin. Before trying to replace it, which according to the manual, requires splitting the cases and removing the crankshaft, I need to know if the sprocket should free wheel. I know most DOHC Kawasaki's use a sprocket on the tensioner. If anyone else has had one apart that far, please let me know.
Thanks
1975 Z1B
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
  • Motor Head
  • Motor Head's Avatar
Re: cam chain tensioner sprocket
06 Nov 2011 16:21
#487245
Hey I'm not a twin guy, but this is the parts fiche, what are you trying to describe, the crankshaft gear?
  • gmannz1
06 Nov 2011 16:24 - 06 Nov 2011 16:26
#487247
It's the sprocket in the middle of item 6 in the fiche.
1975 Z1B
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
Last edit: 06 Nov 2011 16:26 by gmannz1.
  • Motor Head
06 Nov 2011 16:33
#487253
I would say it should turn quite freely. it is just on a Pin isn't it? No sealed bearing or anything. so if it is stiff it may have Galled, partially seized to the Pin. Case Split to replace?
Ask bountyhunter, he's the Twin Guru.
  • gmannz1
06 Nov 2011 22:53
#487310
That's correct no bearing, just a pin and bushing. I'm thinking the pin may be bent. It comes out as a single unit with the mounting bracket attached attached underneath the top half of the crankcase. Unless there is another way to repair or replace the sprocket.
Thanks for the help
1975 Z1B
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
