Adjusted valve clearances--now get a loud clacking noise
  • Skyman
  • Topic Author
20 May 2006 16:13 #48720 by Skyman
I tried adjusting my valve clearances on my '80 KZ440 LTD. I followed the instructions in the owners manual, and I thought everything went smoothly. But when I fire it up, I now get a very loud clacking noise coming from the engine. :pinch:
I didn't run it very long for fear of damaging something.
Any suggestions on what it might be, or what I should do to try to fix it?
Thx.
West Linn, OR
21 May 2006 00:10 #48805 by Mark Wing
I would double check every thing. These valve trains are a bit noisy with proper valve clearances. How's the oil, old or low oil well make it noisy too.
Mark
Yorba Linda Cal.
21 May 2006 03:49 #48812 by Samwell
Hmmm, a loud clack probably isn't good...Was it running well prior to the adjustment? Did you have to make any large changes to your valve clearances? Would it turn over smoothly by hand before you bolted the cover down? Did the noise seem like top end noise or something else? The valves may tick when adjusted.
The best thing to do now is to open it up again and have a look around and re-check your clearances. Let us know what you find...
Sam
Thx.
  • Skyman
  • Topic Author
21 May 2006 19:05 #48975 by Skyman
Thanks both of you for your replies.
I first checked the oil. It was a little low, so I topped it off.
Next, I opened the valve caps back up to check the clearences once more. I was surprised to find that both the exhaust valves clearences had become quite loose. I thought "A-ha! There's the problem." So I re-adjsted them, and tightned the locking nut down good and tight. When I fired it up, the clacking noise was still there. :S Also, when I pulled the plugs, they looked slightly wet.
So again, I opened the caps and checked. Once again, the exhaust valves were quite loose. :huh:
I started again, re-re-adjusted the clearences, and also checked the intake clearences--they were good. Tightened everything down good and tight. Fired it up. This time the noise wasn't quite as bad, but it was quite noticable. Before I started, there was a very slight clicking noise from the top end, but not nearly as loud as it is now.
It seems to run okay now--for the short time that I ran it. Again, I am a little afraid to run it to long for fear of damaging something. I haven't ridden it yet. Just rev'd the engine a bit.
Samwell, to answer your specific questions, it was running well prior to adjustment. I don't think I made huge changes to the adjustment. To get the feeler guage in, I had to back it out a bit. Then I tightened it down on the guage until there was some friction pulling it out. Then I tightned the locknut there. It did turn over smoothly by hand, though I never removed the top cover. Just the valve caps. The noise does seem to be coming from the top end. You said valves may tick when adjusted, but this is louder than I think could be considered "normal".
Any ideas?
West Linn, OR
21 May 2006 21:24 #49009 by Mark Wing
It's tough to say without hearing it but these top ends do rattle a bit. There's no hydraulic cushion like in a car, these are all metal. When adjusted there's some clearance so it has to make noise. I'm used to a noise top end, my bike with hot cams runs even more clearance.
Mark
Yorba Linda Cal.
  • Skyman
  • Topic Author
21 May 2006 23:41 #49029 by Skyman
Mark
Thanks. Yeah, I know it's hard to diagnose without actually hearing it. All I can say is that it is quite loud, and I have a hard time believing that this is "normal".
West Linn, OR
22 May 2006 10:18 #49118 by BARNEYHYPHEN
Skyman, Please excuse this real real stupid question but, are you absolutely sure the cams were in exactly the right orientation for each valve, when you adjusted the clearances?
  • Duck
  • e vica na i sau na ga
22 May 2006 11:07 #49128 by Duck
Take your valve covers back off.
Take plugs out.
Turn it over by hand and watch what's going on all the way around.
If nothing looks odd, for example cams rocking back and forth because the chain is loose, start feeling things.
Grab the end of a rocker and turn the engine over.
When it's at it's loosest point, wiggle it up and down by hand. You'll find out if any are way out of spec pretty quickly this way.
  • Skyman
  • Topic Author
22 May 2006 12:57 #49163 by Skyman
Not a stupid question at all. If I understand you correctly, to the best of my knowledge, they were in the right position. I followed the instructions in the owners manual.
1. I removed the valve caps and plugs, and also removed the breaker cover.
2. I used a socket wrench to crank the engine counter-clockwise until the right intake valve went down, then up, then continued to turn until the "T" mark aligned with the timing mark.
3. I adjusted the right intake/exhaust valves.
4. I then made one rotation with the socket wrench until the "T" mark again aligned with the timing mark.
5. I then adjusted the left valves.
Does that sound right to you? Does that answer your question?
West Linn, OR
  • Skyman
  • Topic Author
22 May 2006 13:04 #49167 by Skyman
Take plugs out.
When you say "take your valve covers off", do you mean just the round caps, or the whole top cover? I'm not near my bike right now, so I'm going by memory. With just the caps off, I can't see much besides just the valve tops and the rockers. I can't really see the cams themselves to see if they are "rocking back and forth". Do I need to take off the whole top cover to see what you are describing or should I be able to see this with just the caps off?
Sorry for being so naive. This is all new to me, and I'm trying to learn it. Thanks for your help.
West Linn, OR
  • Duck
22 May 2006 13:16 #49172 by Duck
Caps should be enough. With flashlight you should be able to see enough of the cam end of the rocker to tell if there is anything unusual going on. If it was running fine before, I doubt there is. Only mentioned it because it's something you can look at while the covers are off.
22 May 2006 13:23 #49174 by BARNEYHYPHEN
Skyman, proceedure certainly sound good to me, right on the money. Try what Duck suggests to see if you can glean any more info. Good luck, let us know.
