Piston Rings Issue - Need your help
- Sleepy
Re: Piston Rings Issue - Need your help
21 May 2006 06:20
steell wrote:
Ive never used them, but I quickly crossed them off my list of companies to buy parts from when I checked out there prices - not just a little expensive, f*** ing price gouging expensive...
$200 for a dyna-s (list is $149 and you can get them for $120 shopping around)
$70+ dollars for a top-end gasket set. (I spent $40+ for one).
I dont begruge anyone making a profit, but there pricing is outragous.
I have read lot's of positive things about Redline, and no negatives, and they specialize in the KZ models, while it's pretty tough to find anyone else that are worth anything (commercial shop wise) anywhere near Chicago that will work on the KZ's..
kz650 gs750 cb750
- steell
21 May 2006 10:04
Sleepy wrote:
I should have been more specific, I was talking about the quality of their work, not their prices
I won't buy anything from them either.
steell wrote:I have read lot's of positive things about Redline, and no negatives, and they specialize in the KZ models, while it's pretty tough to find anyone else that are worth anything (commercial shop wise) anywhere near Chicago that will work on the KZ's..
- rammy
21 May 2006 10:28
welcome too the site.I am near midway airport so I am real close to chicago and I am willing to give you a hand with your bike.Give me a u2u with contact info.Look forward to hearing from you.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- incognito0160
21 May 2006 12:54
There is a guy in McHenry that works on old vintage Jap bikes. I'll get his name from a friend, i've called him before and he's really helpful.
gotta go dig his number up now.
- wiredgeorge
21 May 2006 16:31
Geesh... my comment regarding cylinder to bore clearance was probably premature. When you have compression problems on an older bike, the valve clearances are DEFINITELY the first thing that should be checked. I am working more and more on other folks bikes and this is clearly a COMMON issue.
- Yzr 1
23 May 2006 20:29
Thanks for all of your imput. You certainly have given me some direction with this piston ring issue that may not be a piston ring issue at all. We will do the drip down test (does anyone have a link with instructions as how to perform this test?) and then look to the value issue.
Thanks again for all of your insight!
1983 Spectre 1100
1982 Spectre 750
1980 KZ1100
Chicago, IL
1982 Spectre 750
1980 KZ1100
Chicago, IL
- wiredgeorge
24 May 2006 06:18
Your leakdown test will do you absolutely no good if you don't adjust valve clearances first! Essentially you force air into a cylinder and listen to where it leaks out. If you have some intake valves hanging open due to a valve(s) sticking open due to lack of clearance and an exhaust valve also sticking open due to lack of clearance, you will get air coming out the intake manifolds, air coming out the exhaust and if the rings are also in poor shape, air coming out the crankcase breather. All you will be is confused! ADJUST VALVE CLEARANCES!!! Once you have those valves sealing, you will have a better shot at locating any compression problem. I also suggest that the lack of valve clearance might just BE YOUR COMPRESSION PROBLEM and you may find you have fixed the issue.
If you do a leakdown, it may be best to have an experienced hand or professional mechanic there as this method takes some practice to perform effectively. I personally don't bother do leakdown tests. With the valves adjusted, if you perform a NORMAL compression test with a $20 autoparts store compression tester, your compression will be within spec or not within spec. If it is not, say 3 cylinders have 130 psi compression and one cylinder has 80 psi, I repeat the test after putting a teaspoon of oil in each cylinder (do only one cylinder at a time or you will have an oil gusher!). Say the compression had been 130-130-130-80... if it goes to 140-140-140-135, then you can assume you have ring seat issues as the teaspoon of oil SEALS the #4 rings for the test. If the compression goes like this after oil testing 140-140-140-90, then you have valve sealing problems as the oil didn't do much for sealing the #4 ring. The advantage of doing the testing the way I do it is that you don't have to buy a leakdown tester (EXPENSIVE) or fabricate on AND you don't have to squat around the engine trying to figure out where the air is escaping... I am not a skinny guy and find squatting with my ear to an engine component undignified hehe
The reason that a bike shop uses a leakdown rather than my method? It is probably the best way to quickly diagnose the problem location and they are more interested in providing some sort of meaningful estimate of costs than I would be. My way of doing it, is that the engine will need to come apart anyway. If a shop finds you have ring issues, they will quote you for OVERSIZED PISTONS, ENGINE BORING and of course, NEW RINGS (and gaskets/labor, etc). If I did this, I wouldn't have my mind made up on the best (cheapest) course of action till I was sure what needed done. Like I already mentioned, I would just swap in another used block/pistons with the correct clearances and parts would be limited to rings and gaskets... labor would be about the same but I would be saving hundreds on the new pistons and engine boring. Again, I stress that if you have ring issues, NO ONE can tell if the ring issues are just ring wear or the piston to bore clearance is too great and new pistons/rings are needed by doing a leakdown or ANY other type of external test.
Post edited by: wiredgeorge, at: 2006/05/24 09:22
Post edited by: wiredgeorge, at: 2006/05/24 09:24
