Loctite on case bolts??? Or antiseize?
- kmberjo
25 Oct 2011 12:21
I guess the subject speaks for itself--seems like a low strength would be a good idea--Blue 242 or 243.
- turboguzzi
Re: Loctite on case bolts??? Or antiseize?
25 Oct 2011 12:27 - 25 Oct 2011 12:28
no need for thread locking in case bolts, you are worrrying for nothing...
if anything, make sure you dont overtorque and strip threads
Last edit: 25 Oct 2011 12:28 by turboguzzi.
- T_Dub
25 Oct 2011 12:37
Yeah, just jam em in there. They most likely wont get stuck. Mine weren't stuck after 32 years.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- loudhvx
25 Oct 2011 13:03
Definitely not loctite.
I've been using antiseize for years on case bolts. It helps in these rainy climates. The steel bolts, after their plating gets scratched from a few removals, will cement together with the aluminum case threads with just a little bit of water.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- turboguzzi
25 Oct 2011 15:11
never had problems in 30 uears and around here they do use anticing salt on the roads and i do ride in freezing weather.
if you do go for antiseize (no manual will tell you to do so) be REALLY careful with torque as it is essentially also a lubricantand and the handbook dry torque values will be too high.
unless you live AND ride in freezing weather, no need, IMHO of course.
25 Oct 2011 21:10
Look in the torque table in your Kawasaki service manual. It is very specific as to which bolts require non-permanent locking agent. Don't bother using it on the others as you will only be inviting trouble. Ed
- SlowRide
11 May 2012 15:49loudhvx wrote: Definitely not loctite.
What torque values do you use? I have one case already with several broken bolts in it, Im going to use anti-seize this time.
- Injected
11 May 2012 16:53
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
11 May 2012 17:39
Use the torque values specified in the Kawasaki Service Manual. The only exception I am aware of is the cam caps. For those, ask for the correct value on this site prior to torquing because depending on which bike/model/manual you have manual may have too high a value. This has led to some stripped bolt holes in the cylinder head. I have always torqued bolts near the low end of the torque range and have not yet experienced any stripped threads. Using anti-seize is not an absolute necessity, but it is not a bad idea where bolts are going into the aluminum engine. On a related not; the cross head screws that look like Phillips and NOT Phillips. They are Japanese Industrial Standard (JIS) and using Phillips screwdriver tips on them will quickly ruin them. See:
kzrider.com/forum/13-bike-related/519588-tips#519601
and
kzrider.com/forum/2-engine/452802-loud-c...hile-cranking#452872
and
- andy9802gt
- If it tastes that good, eat it yourself.
11 May 2012 19:41kmberjo wrote: I guess the subject speaks for itself--seems like a low strength would be a good idea--Blue 242 or 243.
I would use the green, wicking stuff so that you're sure it gets all the way in there. Wouldn't want the motor to fall apart while riding now would we. Don't worry about what the manual says pertaining to this as I'm pretty sure that the engineer that worked a 1000 hours deciding where to put fasteners and what to use for lubricant and torque had his head firmly up his ass.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- VenturaRider
11 May 2012 19:53andy9802gt wrote:kmberjo wrote: I guess the subject speaks for itself--seems like a low strength would be a good idea--Blue 242 or 243.
Yipeee! more fun with goop! I'm off to the Home Depot for a selection of masons trowels to apply it. :woohoo:
Box stock 75 Z1900
74 Z1900
Ventura Ca.
74 Z1900
Ventura Ca.
11 May 2012 20:06
:laugh: :laugh: :laugh: :laugh: Nah, we don't need no stinkin' goop; heck, we don't even need bolts! Just weld everything together! That ought to hold 'er. :laugh: :laugh: :laugh: :laugh:
