E3 Spark Plugs
  • kz6fittycent
  • kz6fittycent's Avatar Topic Author
E3 Spark Plugs
18 Oct 2011 17:58
#483979
Has anyone tried E3 Plugs with any success? I have been thinking about using them on the next tune up but I have heard mixed reviews (many positive and a few negative conjectures). I was wondering if anyone had used them and likes them. In the past, I have used ye old Split Fires in two strokes with a lot of success so I am not afraid to try any new technology. I just don't want to waste money on a product that someone has found doesn't work well in the KZ 650.
BTW, I have been doing some research, so I am not interested in learning about the operating principles of the spark plug. I know that seems a little off putting, but it REALLY gets old and very tedious trying to read through all the minutia.
I am a mechanic by trade so this is nothing new to me, I am just looking for someone with experience with this product.
Thanks in advance,
P.S. As I read this post, I hope that no one thinks that I am some jerk. I am sure that there are others in the forum who know what I am talking about with those who think it's cool to pontificate about meaningless garble without answering a simple question. Yes, it has really been a thorn in my side...LOL.
I would like to buy a vowel...and parts for my rusting motorcycle.
1978 KZ650-B
Re: E3 Spark Plugs
18 Oct 2011 18:43
#483985
Looks like hype to me, but I've never tried them. Maybe someone on this site with a stock bike who has access to a dyno can do a side by side comparison between E3, ND, and NGK plugs of the same heat range to see what, if any, performance differences result.
  • jms3257
  • jms3257's Avatar
Re: E3 Spark Plugs
21 Oct 2011 17:18
#484508
On one of the car shows that Spike TV has on Sat. Sun. Mornings, they once did a comparison of several plugs including the E3. Ran a baseline test on an engine dyno. Kept everything the same just changed plugs. The E3 got a small boost in HP. Would have thought more about it if E3 wasn’t one of the sponsors of the show.
Hope this isn’t the dribble you were trying to avoid!
Jim Smith
1980 KZ1000 LTD
Been away from riding for way too long, enjoying the journey back.
  • bountyhunter
  • bountyhunter's Avatar
Re: E3 Spark Plugs
22 Oct 2011 03:02
#484620
The never ending scam built on the sand that if a poorly functioning ignition can reduce performance, then a SUPER ignition must improve performance.
All those extra spark "tongues" do absolutely nothing. The spark jumps whatever path is "shortest" or least resistant based on the ionized air path across the air gap.
It probably won't hurt anything, I guarantee it won't help anything.
  • BSKZ650
  • BSKZ650's Avatar
Re: E3 Spark Plugs
24 Oct 2011 11:38
#485038
I saw the show that did the plug run on the dyno, and yes it was paid for by E3 but, it did show a boost in HP.
I have been around multi electrode plugs in the Gas industry, the main thing you gain is less chance of miss fire since the spark does take the least path of resistance, so the thought is if it has a chance of miss fire due to a fuel or weak spark issue you have 3 more chances to get the plug to fire.
Bottom line, if your ignition is working like it should I really dont see the need in the expense of the plugs
77 ltd1000, current rider
76 kz900, just waiting
The following user(s) said Thank You: kz6fittycent
  • TexasKZ
  • TexasKZ's Avatar
Re: E3 Spark Plugs
24 Oct 2011 11:57
#485040
These seem to be based on the same theory as the so-called surface gap plugs used in the 1960s in two strokes. As mentioned above, it was a way to hedge your bets against misfire. With the advent of more dependable electronic ignitions, those plugs went the way of the dinosaurs.
  • TexasKZ
  • TexasKZ's Avatar
Re: E3 Spark Plugs
24 Oct 2011 12:00
#485041
P.S. If they really make measurable horsepower, then I'm sure Saleen, SMS, AMG, Lingenfelter and all the rest would be using them.
  • TexasKZ
  • TexasKZ's Avatar
Re: E3 Spark Plugs
24 Oct 2011 13:47 - 24 Oct 2011 13:48
#485057
Some additional reading
www.se-r.net/engine/specialty_spark_plugs.html
Well slap me silly, they're available again.
www.ngksparkplugs.com/products/spark_plugs/surface.asp
Last edit: 24 Oct 2011 13:48 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
Re: E3 Spark Plugs
24 Oct 2011 13:57 - 24 Oct 2011 13:59
#485060
Even more
File Attachment:
File Name: iame26-spa...lugs.txt
File Size:18 KB
The pdf version has some sexy charts and graphs, but I don't know how to post it.
Last edit: 24 Oct 2011 13:59 by TexasKZ.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: E3 Spark Plugs
24 Oct 2011 17:16
#485086
muzzy did dyno tests on there dual plugged heads back in the 80's. he said that there was no hp gain, but they were able to run less advance. i asume this was due to the shortened path the flame now has to travel.
so if he saw no hp gain with 2 plugs, i cant see how it posible to make a gain from 1 slightly dif plug..
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kz6fittycent
Re: E3 Spark Plugs
26 Oct 2011 18:20
#485487
No!! I saw that episode and thought the same thing, too. Thanks for the input. I found out that they have a MONEY BACK GUARANTEE...so I might just give them a try. Plus, they have a 5yr/100k mile warranty.
1978 KZ650-B
  • kz6fittycent
Re: E3 Spark Plugs
26 Oct 2011 18:22
#485490
[strike][/strike]
Well, the surface gap plugs are still in use with rotaries...and I'm a rotary guy. I thought the same things about the surface gap thing but wasn't sure.
1978 KZ650-B
