Iridium Plugs, worth it?
- fxdl2051
10 Oct 2011 09:30
I've been reading about how great iridium plugs are, anyone tried these on their KZ's. Just wondering if they do add any performance to justify their expense or I should just stick with current plugs? Anyone know if they run any hotter or they spec out same as OEMs?
Thanks much,
Ken
Thanks much,
Ken
- Motor Head
Re: Iridium Plugs, worth it?
10 Oct 2011 09:46
No don't waste your money, better spent elsewhere on your bike.
- bountyhunter
10 Oct 2011 16:28They do nothing to increase performance but do last longer. They are worth it in cars where changing plugs is a PITA, like mine where you have to take a bunch of junk off to get to them. cars now have coil-on-plug design with electronics on top so there is a lot of junk sitting above the plugs that has to be removed.fxdl2051 wrote: I've been reading about how great iridium plugs are, anyone tried these on their KZ's. Just wondering if they do add any performance to justify their expense or I should just stick with current plugs? Anyone know if they run any hotter or they spec out same as OEMs?
Thanks much,
Ken
On bike's, not really an issue.
- mtkawboy
10 Oct 2011 21:58
Put them in my XB12 Buell.............nothing
- KZQ
- Administrator
10 Oct 2011 22:32bountyhunter wrote:They do nothing to increase performance but do last longer. They are worth it in cars where changing plugs is a PITA, like mine where you have to take a bunch of junk off to get to them. cars now have coil-on-plug design with electronics on top so there is a lot of junk sitting above the plugs that has to be removed.fxdl2051 wrote: I've been reading about how great iridium plugs are, anyone tried these on their KZ's. Just wondering if they do add any performance to justify their expense or I should just stick with current plugs? Anyone know if they run any hotter or they spec out same as OEMs?
Thanks much,
Ken
I'm with BH,
They were designed to extend the duty cycle and nothing more.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- fxdl2051
11 Oct 2011 04:51
Thanks everyone, another majick bullit dud I guess.
ss^,
Ken
ss^,
Ken
- jeffasaki
11 Oct 2011 09:01
About these plugs
one of my bikes a 78 kz1000
was having problems with carbon fouling due to valve stem seals needing replacement
i installed a set of ngk iridium plugs
these plugs have helped a lot with starting
the bike smokes a bit at startup until it get warm
but starts a lot easier then it used to
when i take a plug out to read it it will look black when the bike is not warmed up
if i take a look after a good run the plug has the nice light brown burn that we all want
a little pricey
but a lot easier then doing a valve stem seal job
just my 2 cents
a little pricey
just my 2 cents
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
