Hi friends
- Z1Bama
17 May 2006 19:07 #48114
by Z1Bama
Hi friends was created by Z1Bama
Im installing 3 ohm ACCEL coils/8.5 mm plug wires along with dyna s's in the points box on my 1974 Z1 900. The old dyna 3 ohm coils came off and were bolted thru the holes in the bars running thru the coils. was this considered a grounded mount? The ACCELs are a little longer so the bars the dynas were bolted to are coming off and will use mounting bars that came with the new ACCEL kit. Anyway was it correct to bolt these kinda coils thru the holes on each end this way? Thanks for your comments
- Lorcan
- Speed Loony
- Thank you received: 59
18 May 2006 00:35 #48178
by Lorcan
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Replied by Lorcan on topic Hi friends
Yes that's the correct way to mount them.
760cc - 8.69@162mph
- loudhvx
- Thank you received: 1616
18 May 2006 09:14 #48234
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Hi friends
Electrically, the core of the coil doesn't need to be grounded.
1981 KZ550 D1 gpz.
Other links.
- Z1Bama
21 May 2006 22:04 #49018
by Z1Bama
Replied by Z1Bama on topic Hi friends
Thanks guys.
