clutch release
- madart
clutch release
18 May 2006 04:45
the clutch release on my 80 z650 is lacking a few ball bearings.. ie all of them! does anyone know where i can get a repair kit, the offending balls or a new one in the uk?
tryed all the breakers, ebay, normal Zed places but up to now i've drawn a blank
its the only thing i can't find to finish the bike.. and it aint going anywhere without it!!:S
thx
thx
- wiredgeorge
Re: clutch release
18 May 2006 05:39
Not sure I know what a "clutch release" is. Help us out by copying the
www.buykawasaki.com
parts diagram and posting it with the part you need marked. I can only think of one ball bearing used between the clutch pressure plate pusher and long rod that goes from the left to right of the engine. I think this is a standard 3/8" ball bearing (can't recall size for sure).
- madart
- hwms
Re: clutch release
18 May 2006 10:46
I would suggest a "Bearing Supply Store". They can, generally, supply small steel balls. They will need a sample for size.
DeJay Distribution, LTD.
Crow Borough, East Essex, UK
Post edited by: hwms, at: 2006/05/18 17:12
- wiredgeorge
Re: clutch release
19 May 2006 06:43
Sorry for my ignorance. I had NO idea that was called a clutch release or there were bearings hiding under the plastic. I though it would just glide along in the worm sleeve. Almost all bearings on a KZ are SAE (inch) sized and not metric. I would also think that if you watched US eBay, the whole thing would come up on auction frequently. I would also have someone do a zedder.com software parts look up to see which of these things are the same as I can't imagine Kaw making a lot of different "clutch release" mechanisms since they all do pretty much the same thing.
- madart
Re: clutch release
19 May 2006 17:33
thanks
i did plan on trying some bearing suppliers etc but the whole feckin job is screwed up now! a "mate" was checking round the big breakers up in newcastle, the retainer sleeve clutched in his sweaty little palm, the useless prat has only gone and lost it!
just to make it worse he's away all weekend then off to the IOM next week, so thats the job total bolloxed..
on the bright side i've found a v cheap complete SR :laugh:
- 77kz700?
Re: clutch release
19 May 2006 18:06
Not sure if this fits yours, but here's one I spotted on ebay...
Item number: 4639880393
(couldn't get the target to cut and paste)
I used a 900/1000 APE clutch pusher even though it didn't list it fitting the 650 and it works, so I hope this works too!
CHEERS!
CHEERS!
