head reassembly- what assy lube do you use on valve stems/guides?
- Trav
15 May 2006 15:47
Well, I am asking for your opinion.
My head came back from the machine shop with a whiteish/yellow grease already on the valves.
My clymer manual calls for "molybdenum disulfide grease"
A guy at work said "no, just use 90 weight gear oil. What lubes it when it's running, ya know?" Which makes sense.. but then I started to think "well, if the valve guide seals actaully DO seal.. what gets down there!" Of course maybe they just keep too much oil from getting there, but a little gets by. I'm not sure.
Also, the guy from work said "Do NOT use white lithium grease. As soon as it gets hot, it gets hard as a rock" and that "alot of machine shops do that, and alot have stuff come back"
My neighbor actaully works at the machine shop where AI had my head work done. He didn't do it, but maybe he knows what grease they might have put on.
- Duck
- e vica na i sau na ga
Re: head reassembly- what assy lube do you use on valve stems/guides?
15 May 2006 16:12
Used externally where the volatiles can bake out, the Li grease will get hard over time. It's quite a long time too. As an assembly lube, IMO and experince, the oil washes it off and it's gone after an oil change.
IMO, grease is good if you don't know how long it's gonna be before you get around to the assembly. If you're gonna put it together right away, oil is fine.
-Duck
-Duck
- Trav
15 May 2006 16:58
Well my concern is that I put the head together, and I would have to take the valve springs all back out to remove the grease. However, sitting there with or without springs, it won't get put back on the bike until I get my block back from APE. That probably won't be until next week (HOPEFULLY NO LATER!)
- Duck
16 May 2006 05:10
The springs get a lot of oil. It will rinse the grease off in no time. As long as the head is clean, there's no reason to remove the grease.
- kx_125_pilot
16 May 2006 11:35
i would jsut use normal engine oil.....its seems to work:P
- RomSpaceKnight
16 May 2006 14:04
I use STP oil treatment as an assembly lube. Nice and thick with similiar properties to engine oil, totally compatible.
- Leather
16 May 2006 14:37
same here.. STP or motor honey ..
- Zthou1977
16 May 2006 15:49
I'd use what the factory manual calls for: a thin coat of molybdenum disulfide grease on the valve stems. My reasoning is that they wrote the book on their own bike, so they'll know what's best. For instance: when installing the valve guides, they prescribe clean engine oil. It reads like they thought about it.
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- BSKZ650
17 May 2006 04:48
the white 105 assembly lube is good stuff, it will last for a while and when it gets warm it will melt and lube all the parts. it does last for a while also, just need to make sure and keep it coverd as it will attract dust and dirt also.
I would also use a cam assembly lube on the cam lobes and lifters, this is a high pressure lube that will stay on the cams until the oil sets in, and this will also dissipate with heat
77 ltd1000, current rider
76 kz900, just waiting
