82 KZ650 with kick start?
- ravenz07
06 Sep 2011 21:53
Do some 82s come with a kick start? How much of a pain is it? Is it possible to install an electric starter?
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
Re: 82 KZ650 with kick start?
06 Sep 2011 22:08
All KZ650s came with electric starter. Before 1981 they also had a kickstarter; 1981 and later had no kickstarter. Ed
- ravenz07
06 Sep 2011 22:41
Hmmm all had an electric start? I am looking at one the seller says is an 82 but I am pretty sure I see a kick start in his photo
06 Sep 2011 23:01
If it has a kickstart it is not an '82 engine. Maybe the engine was swapped sometime in the past.
- ravenz07
06 Sep 2011 23:49
The VIN should be stamped on the ride side of the motor right?
07 Sep 2011 00:51
No. The VIN is stamped on the neck of the frame next to the white label (which also shows the date of manufacture, but may be missing). The engine serial number is stamped in the top of the right side of the engine. It would be highly unusual for that to match the VIN, but that number may be helpful in narrowing down the year of the engine. Ed
Last edit: 22 Jan 2013 04:28 by martin_csr.
- steell
07 Sep 2011 09:40
Pre 81 had electric and kick, 81 and later had electric only.
Both 81 and newer 650's and the four cylinder 750s can be modified by adding the earlier 650 kick starter, but you have to split the case to do it.
