Frozen oil drain plug - how to change oil?
  • repsolgamma
  • repsolgamma's Avatar Topic Author
05 Sep 2011 14:38
#474356
Been busy this summer in the resurrection of a rescued 1976 KZ900 and need some 411 on how to change oil without removing the drain plug.
Its OK to make fun of my question, have not been able to afford a real mechanic to remove the stripped plug yet?
El cheapo rides again!!!!!!!!!!!!!
  • T_Dub
  • T_Dub's Avatar
Re: Frozen oil drain plug - how to change oil?
05 Sep 2011 14:40
#474357
Ahhh, without pulling your pan off there isn't really another way.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • P21
  • P21's Avatar
05 Sep 2011 14:52
#474361
remove filter bolt let drain alittle add oil
as to the drain plug bolt get a set of vise grips with good Sharp jaws on them put on bolt hit with hammer the correct way to loosen
Kawasaki KZ 1000 Police (2002) P21
  • Kapahulu
  • Kapahulu's Avatar
05 Sep 2011 15:29
#474364
If the Z1 and KZ's are the same (I think they are) you can remove the oil filter and get a lot of the oil out of the crankcase. Not a thorough job but at least you can change most of the oil and the filter too while you're at it.
2strokeworld.com
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
05 Sep 2011 16:11
#474373
I have used pipe wrenches,vice grips,and chisels to remove drain plugs previous owners have buggered up.
Just try and remove it after the engine is warm.
After I finally get them out I use my bench grinder to grind them down so a wrench will fit on them.
Roy
05 Sep 2011 16:23
#474374
Just weld a steel bar to the drain plug. Ed
  • martin_csr
  • martin_csr's Avatar
Re: -
05 Sep 2011 19:55 - 21 Feb 2013 17:54
#474414
Last edit: 21 Feb 2013 17:54 by martin_csr.
  • bountyhunter
  • bountyhunter's Avatar
05 Sep 2011 19:56
#474415
You can do it with one of those electric pumps. My headers used to block my drain plug so I would do changes by dipping the plastic hose of the electric pump down through the drain plug and slurping out the oil. I could get about 3 1/2 of the 4 quarts out that way. Pulling the headers every time was just a royal PITA.
  • cdvanns
  • cdvanns's Avatar
05 Sep 2011 23:59
#474474
I used a file on mine and squared it up enough to get a socket on it,the metal is soft and although it took some patience it worked. After you get it off you can square it up good an proper! Good luck...
1978 KZ1000 A2
  • donthekawguy
  • donthekawguy's Avatar
06 Sep 2011 02:11
#474514
By just changing the filter you would only get about 1/4 of a quart out. Try a small pipe wrench with a pipe on the end. The pipe wrench will tighten on the plug the harder you pull on it.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
06 Sep 2011 03:49 - 06 Sep 2011 03:49
#474523
May also heat the plug and surrounding area with a propane torch immediately prior to removal attempt.
And, of course, after removal, replace with a new plug.
Good Fortune! :)
Last edit: 06 Sep 2011 03:49 by Patton.
  • wireman
  • wireman's Avatar
06 Sep 2011 06:01
#474546
craftsman makes a really good set of sockets just for that purpose B)
