Valve seals and o-ring questions
  • gwolever
  • gwolever's Avatar Topic Author
04 Sep 2011 23:27
#474246
Hey guys. As I have my engine apart to clean and replace some worn parts, I was wondering (since I got new valve seals with my Vesrah full gasket kit) if I should just go ahead and install them. The bike wasn't smoking or anything before I started the rebuild project, but she is 30 years old. I don't have a valve spring compressor, but looking on here I saw some make-shift ones you guys have used using c-clamps that I could easily make.
Second question. I need new cylinder head o-rings. I noticed they were about 80 cents each on Z1, but they are out of stock. Found them on bikebandit.com for just over $9 each. WTF? Anybody know where to get some cheaper than that?
1982 KZ1000 CSR
Re: Valve seals and o-ring questions
05 Sep 2011 00:46
#474267
Ronayers. Not cheap at $6.33, but less than $9.
  • TexasKZ
  • TexasKZ's Avatar
05 Sep 2011 11:34 - 05 Sep 2011 11:35
#474328
As long as you are there, I'd vote for replacing any 30 yr old seals. However, a bunch of folks around here have had really bad luck with aftermarket valve seals. Spend the money for the genuine Kawasaki seals to insure a happy life.
Last edit: 05 Sep 2011 11:35 by TexasKZ.
