How I fixed my KZ engine problems (after a year!)
- ELCouz
27 Aug 2011 22:46 - 27 Aug 2011 22:49
Hi,
After a year of troubleshooting on my GPZ 750 R1 1982, i think it (the solution) deserve to be explained here for further reference!
Previous long thread explaining what i did have --- > kzrider.com/forum/2-engine/460495-solved...nstallingoverheating
In short:
Engine has been overbored (scratch damage) to fit the wiseco 810cc piston kit
-Engine running rough at on long stop/red lights (drop from 1100 rpm to 700 rpm , fluctuate)
-Engine would halt on hard braking (nearly stoppie!)
-Engine would halt running rough for too long (red lights)
-Engine Abnormally hot
What has been checked hundreds of time
-Idle speed
-Carb sync
-Spark coils
-Fuel level
-Valve clearance
-Leaks Leaks!!!
-Clutch adjustment
-Jetting
-CDI box
-Pickups & mechanical advancer
I spend a lot of money changing the following parts while praying its gonna fix something:
-Spark plugs coils & wires (dyna coils)
-Ordered from #110 to #145, over 50 main jets (yes! fifty pcs)
-Spark plugs, NGK BR9EIX iridium
-Intake boots and airbox boots
-New regulator/rectifier (had already one thought)
-New battery
-Changed electrical connectors
Enough listing!:laugh:
Ok so when i was again on a spending spree on Z1Enterprises decided to purchase new clutch plate,steel plates, APE bearing push rod and clutch springs.
Boy the clutch was partially the culprit of all my troubles !
Plates where distorted and always dragged a little at any clutch play , adjustment possible!
Enough to stall the engine sometimes when plates sticked together in gear (at stops)!
Another thing which misled me, i think it was never described here that's why it was for me Counterintuitive...
Exhaust will backfire , pop and crackles when TOO RICH! (damn it!)
Everyone was describing this as a TOO LEAN problem ... no, not on my bike
I raised from #135 and kept rising until #145 when i found in a car forum about carb adjustment that too rich will cause this symptoms instead of BOGGING like people describe here
So switched to #132.5 and everything's fine ... yay! Got plenty of main jets to sells
Another cool thing i found... you can change the float level, main jets and pilots jet on BS34 while installed! (airbox , no pods)
You must have patience thought
... this prevented from wearing my intake boots,collar and airbox boots from removing and installing the carb rack too often!
A big bonus no carb sync required since you never removed them!
My heart is empty and my pocket too now
hope this helps!
best regards,
laurent
In short:
-Idle speed
-Carb sync
-Spark coils
-Fuel level
-Valve clearance
-Leaks Leaks!!!
-Clutch adjustment
-Jetting
-CDI box
-New battery
hope this helps!
best regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 27 Aug 2011 22:49 by ELCouz.
- Topper
Re: How I fixed my KZ engine problems (after a yea
27 Aug 2011 23:21
Way to stick with it and finally find the solution!
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- AtLarge
Re: How I fixed my KZ engine problems (after a year!)
28 Aug 2011 09:50
Good to know. Thanks for the follow up!
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
- KZJOE900
- Administrator
Super Users
28 Aug 2011 09:57
Patience is truly a virtue. Boy! You really had some obscure issues. This why I enjoy reading these posts so much. Always something to be learned. Way to hang in there.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- srosebrock
28 Aug 2011 14:18
What tipped you off that it was the clutch?
1982 KAWASAKI KZ440-A
- Mcdroid
- Gone Kwackers
28 Aug 2011 14:25
Excellent post Laurent! Thanks.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- ELCouz
28 Aug 2011 16:11What tipped you off that it was the clutch?
The primary chain was rattling like a gatling gun (once in a while) when in red light in first gear !
In neutral it was okay all the time but switching to neutral while moving when coming to a red light is hardcore!
Yeah thanks Mcdroid , your KZ750 R1 seat you sold to me last year still hold very well btw
regards,
laurent
- Godfrey
29 Aug 2011 00:19
this is good to know , somewhere else to look, I still have issues with my bike recovering an idle at stop signs when hot, and I eliminated the possibility of heat boiling the gas in the carbs. Glad you got your problem fixed, enjoy the ride.
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
29 Aug 2011 01:15Godfrey wrote: ...I still have issues with my bike recovering an idle at stop signs when hot, and I eliminated the possibility of heat boiling the gas in the carbs....
Often results from too tight valve clearances.
- ELCouz
29 Aug 2011 11:00this is good to know , somewhere else to look, I still have issues with my bike recovering an idle at stop signs when hot, and I eliminated the possibility of heat boiling the gas in the carbs. Glad you got your problem fixed, enjoy the ride.
One thing you should try...whenever possible switch to neutral at stop or when coming to a stop to see if it make a difference ... could be that too
clutch drag is possible like i had with the warped plates
regards,
laurent
- mark1122
- Keep twisting it
29 Aug 2011 13:18
glad to hear u have solved the problem.
its good to hear about the cure after so much hard work.
Well done.
Well done.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- roy-b-boy-b
29 Aug 2011 14:15
It seemed I was lucky when I got back into the old bikes,mostly carb cleaning. The more bikes I bought the more problems that came up.
I finally got very good at trouble shooting. I guess that's what it amounts to,trouble shooting.
One year at the meet in Ohio Andy brought a 650 that had given him trouble for a long time and would not start.
I tried to start it and after installing a set of carbs I had and it still would start I removed the gas tank and switched the coil wires and it fired right up.
After a while (years) :blink: a person will become good at the trouble shooting.
What I see most on the site is someone asking advice and not applying the years of expierence of riders thet have gone through the same issues.
I understand when someone doesn't want to adjust valves but if the valves need adjusting,they need adjusting. This one issue will affect so many areas that one will want to give up.
I followed your thread on this bike and I applaud you on hanging in there until you have found the problem and expanded your experence level to a degree where the bike is so familar to you that any problem after this will be a breeze. Roy
