kerker pipes
  • pimpstic
  • pimpstic's Avatar Topic Author
kerker pipes
23 Aug 2011 16:35
#471193
how is the exhaust suppose to stay in the header
78 KZ1000 LTD
YOUR NOT RIDE'N UNLESS YOUR KZ RIDE'N
  • Mcdroid
  • Mcdroid's Avatar
  • Online
  • Gone Kwackers
Re: kerker pipes
23 Aug 2011 17:12 - 23 Aug 2011 17:13
#471202
:huh: No offense, but can you rephrase the statement?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 23 Aug 2011 17:13 by Mcdroid.
  • otakar
  • otakar's Avatar
Re: kerker pipes
23 Aug 2011 17:18
#471203
Yeah :huh: :unsure: 2x.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
Re: kerker pipes
23 Aug 2011 17:20
#471204
Are you attempting to ask "how the tailpipe is supposed to be attached to the collector"?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Re: kerker pipes
23 Aug 2011 18:30 - 23 Aug 2011 19:41
#471209
pimpstic wrote: how is the exhaust suppose to stay in the header
Kerker connects to the engine head same as stock.
Exhaust clamp presses split collars against pipe flanges that press against round copper gaskets inside the engine head ports.
The four header pipes join at a collector.
Kerker muffler fits snugly over the collector.
A decorative chrome "hose clamp" tightens the muffler onto the collector.
Good Fortune! :)
Last edit: 23 Aug 2011 19:41 by Patton.
  • cavanaughracing
  • cavanaughracing's Avatar
Re: kerker pipes
23 Aug 2011 18:42
#471210
Well...if you welded a cap over the end of the muffler, that would do the trick :woohoo: Not a good idea but that's the answer to the question :silly:
  • trianglelaguna
  • trianglelaguna's Avatar
Re: kerker pipes
23 Aug 2011 19:02
#471215
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Re: kerker pipes
23 Aug 2011 19:06
#471217
The automotive world equivalent of sticking a potato into the tail pipe.
(Those certain high school teachers used to get really P.O.'d) :lol:
Good Fortune! :)
  • trianglelaguna
Re: kerker pipes
23 Aug 2011 19:19
#471220
the picture shows a Kerker pipe of the older megaphone type.....
the pipe has a small flanged lip,where exhaust it mates to the ex manifolds..ports..the stock half collars and finned ex collars work together in pressing the ex pipes flange tight...
in this picture the half collars are wrapped with rubber bands to hold them while i work the pipe into place and get the ex collars over the two studs and nuts started...the rubber bands will burn/fall out of the collars later...also in this pic i used the later J-model collars from Z1 ent.com for a cleaner look......note:the split/half collars are backwards under their rubber bands and needed to be flipped to flange out to catch the pipe and collars...took me 5 minutes of wrestling to catch that they were on the pipe wrong....
1976 KZ900
2003 ZX12R
2007 FZ1000
Re: kerker pipes
23 Aug 2011 20:03 - 23 Aug 2011 20:12
#471230
Here's another pic.
A common mistake is fitting the split collars backward.
The flanged ends of the split collars are supposed to be seated inside the groove recessed into the clamp.
The plain end of the split collars faces the flanged end of the header pipe.
Good fortune! :)
Last edit: 23 Aug 2011 20:12 by Patton.
  • pimpstic
Re: kerker pipes
23 Aug 2011 20:25
#471240
I put it in the correct way but for some reason it still moves around
78 KZ1000 LTD
Re: kerker pipes
23 Aug 2011 20:36 - 23 Aug 2011 20:37
#471246
pimpstic wrote: I put it in the correct way but for some reason it still moves around
Some exhaust systems require slightly different length split collars.
Usually, the correct length split collars come with the exhaust system.
However, if the split collars are slightly too short, they won't press the pipe flange tightly enough against the copper gasket.
Good Fortune! :)
Last edit: 23 Aug 2011 20:37 by Patton.
