I broke something else - cam cap heliarc repair?
- Maverick
Re: I broke something else - cam cap heliarc repair?
15 May 2006 19:00
So I took the cap to a welder and he wanted $80+ to do it. He recommended that I just use some JB Weld to hold it together...
1981 KZ1000M1
- wireman
15 May 2006 20:43
Maverick wrote:
can you post the name and address of that machine shop so so i can leave a bag full of burning dog crap outside his door?:whistle: jb weld?:S the kz caps are pretty common i think the j/gpz caps are going to be a little harder to come by.:whistle:So I took the cap to a welder and he wanted $80+ to do it. He recommended that I just use some JB Weld to hold it together...
- Maverick
16 May 2006 04:58
I know... I couldn't believe what I was hearing...
So are the '73 - '80 caps not compatible with the J/GPZ head? Don't they use the same bearing inserts? I hear that the aluminum in the older heads is better anyway... My buddy has a '78 KZ900 and the grain of the aluminum looks totally different.
1981 KZ1000M1
- Mcdroid
- Gone Kwackers
16 May 2006 05:05
Maverick...I have to know...how did you break the cap? I don't bring this up to rub your nose in it, but rather I also have my head disassembled and I don't want to make the same mistake:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- wireman
16 May 2006 06:11
Maverick wrote:
im not sure but ill dig up some older style caps to compare.I know... I couldn't believe what I was hearing...
- wireman
16 May 2006 06:14
oops!
:whistle:
Post edited by: wireman, at: 2006/05/16 09:15
:whistle:
- Maverick
16 May 2006 06:59
Well, I was just tightening the cap down by the two bolts through the doweled corners... I guess maybe that's a no-no. It was going down nicely, no binding or anything... Everything was aligned well. I honestly have no idea what made it snap like that. If it was binding against something, I would expect to see part of the aluminum gouged out, but there was no evidence of that. So next time, I will be tightening in a criss-cross pattern and by a half turn per bolt each time to hopefully avoid another boo-boo.
If it was binding enough to snap that cap, don't you think it would have stripped the threads in the head? I guess not. The fracture of the aluminum leads me to believe that it was just very brittle. There was no bending whatsoever, it just snapped.
Oh! Another potentially complicating factor was that I hadn't removed the cam chain tensioner completely - I had removed the cross wedge, but not the push rod. Still don't think that would matter, but I've been wrong before.
1981 KZ1000M1
- kx_125_pilot
16 May 2006 11:00
Maverick wrote:
jb weld? what an idiot.....that would break just by dropping it on the floor lol
- RomSpaceKnight
16 May 2006 14:12
1. Buy some used cam caps.
2. Install exactly as per manual use plastigage to check clearance.
3. If needed (clearance too small) get a real good machine shop to line bore.
or
Buy used J model head. Up here in the great white north they are as rare as hens teeth.
or
- APE Jay
16 May 2006 14:51
I believe KZ and J/GPZ caps will interchange.
Jay
Jay
