77 KZ1000 No Compression? Need Help
13 May 2006 19:12 #47079 by jeffh27
77 KZ1000 No Compression? Need Help was created by jeffh27
found a guy selling a 77 kz1000a who bought it from a friend, said last year hard starting he put in a dyna
ignition, repainted 26k mi nice project bike.
4 into 1, k&n's, stock carb jets.
there is no compression when turing over the motor, it sounds different, a compression test on #1 needle
does not move, he said he lifted the top cover partially and noticed the cams move, whats lefts-burned holes in the pistons using stock jets and a lean condition?
looks like bike had many miles with this set-up then parked.
I need to be certain before buying it.
reply to me at jeffh27@yahoo.com
  • wireman
  • Visitor
13 May 2006 19:23 #47081 by wireman
Replied by wireman on topic 77 KZ1000 No Compression? Need Help
did you try putting a little oil in cylinder and checking compression? how much does he want for it?
  • Duck
  • e vica na i sau na ga
14 May 2006 05:51 #47125 by Duck
Replied by Duck on topic 77 KZ1000 No Compression? Need Help
What wireman said. If you suspect holed piston after this, have a look with a hand mirror and a flashlight. If it's in Atlanta, I can take a look on or after the 20th. Kind of tied up until then.
-Duck
16 May 2006 14:03 #47773 by jeffh27
Replied by jeffh27 on topic 77 KZ1000 No Compression? Need Help
he wants $650 fit, I found another motor on Ebay.
I'm going that route and rejetting the carbs.
