My engine is funky
  • sitenonme
  • sitenonme's Avatar Topic Author
My engine is funky
18 Aug 2011 02:52
#469694
Whe I get my bike started it will idle and rev just fine it sounds great... So I let it warm up an I put it into gear then when I was letting out the clutch it would just loose hp and bogg out and almost die unless I pull the clutch back in... Then it started to smoke ALOT from the front of the engine but no smoke out of the pipe... So I shut it off and a few minutes later I started it again and it will idle for a second and die and I did it again and tried keeping it alive with some gas and it just died... And it would keep starting but only idle for a second or two... What's wrong?
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
Re: My engine is funky
18 Aug 2011 08:17 - 18 Aug 2011 08:21
#469708
u didnt mention what bike u have,
u didnt mention what work u have done to it
we need more info
check ur clutch would be a good starting point
maybe compression check
maybe valves
maybe alot :unsure:
Last edit: 18 Aug 2011 08:21 by jonnybravo.
  • TexasKZ
  • TexasKZ's Avatar
18 Aug 2011 08:40
#469711
Was the engine working ok before ?
  • sitenonme
19 Aug 2011 02:44
#469951
Sorry... I have a 78 kz650 with dyna s ignition dyna coils Plug wires and new plugs pod filters kerker 4 into 1 and yes the engine ran perfect before... I gave it an oil change and that is the only mechanical things I've done to it
  • sitenonme
19 Aug 2011 02:46
#469952
Also cyl 1-3 get the same hotness and cyl 4 is a little colder and I had to replace the plugs because they were all carbon fouled but the number four was less carbon fouled.... What could this mean?
  • supercharged
  • supercharged's Avatar
19 Aug 2011 03:10
#469962
what oil did you use on oil change... are you sure it was filled?
Did you ride it after the oil change?
I think clutch from limited info.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
19 Aug 2011 11:05 - 19 Aug 2011 11:08
#470014
Carbon fouled plugs and you didn't do anything other than change the oil right?
The smoke out the front is a bit of a concern, did it smell like oil, gas (like too rich) or electrical stuff burning?
Did you fill/top off the tank just prior to this happening?
My gut tells me it's electrical since smoke up front but not out back, no oil all over engine front (assuming that as you didn't mention it as the source of the smoke), lack of power when you tried to roll on the throttle, getting worse now and carbon fouled plugs. I'd pull the tank and look for melted wires and examine the coils too.
Assuming nothing mechanical happened like cam chain/gears/valves or any wiring melt, coil frying, etc, then the first thing to check would be the air filter to make sure you didn't accidentally leave a rag or something covering the air box inlet (carbon issue). Next I'd drain the bowls and see what comes out. If it is funky in any way then I'd drain them all plus empty the tank by removing the petcock from it and rinse it out with good fresh gas. Clean the screen, etc on the petcock as needed and if the gas smelled, looked or was anyway very funky I'd pull the carbs and clean them further. This however doesn't explain the smoke though.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Last edit: 19 Aug 2011 11:08 by KZ_Rage.
