cams and tolerances
  • markosportsbikes
  • markosportsbikes's Avatar Topic Author
cams and tolerances
17 Aug 2011 20:31
#469608
i have acomplete rebuild i have 4x cams i am having problems with gaps for shims is there a formula for the more ratical cams or is the tolerance the same 0.002 0.005 my gaps at this point are 0.010 0.014 every thing is in specs as far as springs valves and retainers please help
  • z1kzonly
  • z1kzonly's Avatar
Re: cams and tolerances
17 Aug 2011 22:23
#469631
I would stick to .004 - .006.
4X sounds like a CWC .420 cam. I have a set of them and they have 4X stamped in them.
I would say they could be ran with shim on top as long as the .006 max is followed.
The following user(s) said Thank You: markosportsbikes
  • APE Jay
  • APE Jay's Avatar
18 Aug 2011 02:35 - 18 Aug 2011 02:36
#469689
4X is probably Andrews 4x. .430 lift. Don't run them with shim on top. CWC is the company that makes the billet blank.
Last edit: 18 Aug 2011 02:36 by APE Jay.
  • TexasKZ
  • TexasKZ's Avatar
18 Aug 2011 08:54
#469714
Andrews says .004 gap. Like Ape Jay says, as a rule, any cam with more than .410 lift should use shim under bucket and piston clearance should be checked.
www.andrewsproducts.com/PDF_files/KZ900-1.pdf
