shaft drive
- baborz72
- Not enough hours!
shaft drive
14 Aug 2011 12:14
Sold my old KZ1000 cause I couldn't get a title. Found a deal on a 750 spectre (82) shaft drive. How do these systems hold up? I've never had a shaft drive bike.
It'll go...or...It'll blow!
- Motor Head
Re: shaft drive
14 Aug 2011 12:51
Shaft drive is Very Reliable, and low maintenance. No chain lube needed.
Some experience a torque issue, from the rear under power. Nothing like some bikes. My buddy has a MotoGuzzi V twin, a piston on each side, talk about Torque issues when under power and engine braking. You get used to it, the 1100 shaft I had I could hardly notice it.
- baborz72
- Not enough hours!
Re: shaft drive
14 Aug 2011 14:59
What about hot-rodding with them? Can you stretch them, or is that more of a pain than it's worth?
- Nebr_Rex
Re: shaft drive
14 Aug 2011 21:47baborz72 wrote: What about hot-rodding with them? Can you stretch them, or is that more of a pain than it's worth?
Same applies with all KZ750s.
810,cams,carbs and pipe
Stretching swingarm on a shaft drive would be a BIG pain in the backside.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Chaotic Reason
Re: shaft drive
15 Aug 2011 19:31
Shouldn't be that big of a deal, should it?
Just get a machine shop to cut the shaft, weld in an extension, and then throw it on a lathe to balance it out. My brother used to do it with cars all the time when he wanted to throw a different rear end on that was a different model from what he had. I think extending the shaft housing in the swing arm might be more involved though... Maybe not... Cut the flange at the front, and then weld it onto an extension tube going back to the swing arm. It would take some work, but you'd definitely be sporting a custom if you did.
Michael
1980 KZ1000 shaft drive
- thug
Re: shaft drive
16 Aug 2011 14:11
Had shafts shortened and lengthened,last one on a GS850 hardtail, with no issues at all.
Not too expensive to have done either.
As for shafties,I love em
Ridden both regularly for over 30 years and I suppose you could say they are slightly different but you soon get used to it.Having said that,isnt every new bike different to ride?
KZ1100 A3 shaftie
- cobura
- forever 2 wheels
Re: shaft drive
16 Aug 2011 15:01
I used to ride a shafty nighthawk. I sold the bike because I never really enjoyed riding it like I do my other bikes. The throttle kind of jumped on and off and it didn't shift very smoothly. It may have been due to other mechanical issues, but ever since then I have never been very fond of shafties. Also, I found it to be much more difficult to remove the rear wheel.
1979 KZ650B3
- garyprather
Re: shaft drive
17 Aug 2011 23:40
I have a 83 1100 shafty and the shifting is nice and smooth. I do not notice a lose of power with this bike at all. I like shaft drive maintenance free. I have no problems getting on it every now and again. It holds to a nice wheelie. I would not shy away from the shaft drives unless you would be looking to change your sprockets.
Re: shaft drive
18 Aug 2011 09:55
I put more than 60,000 miles on a Concours and loved every mile.
