Oil Pan O-Ring
  • Kapahulu
  • Kapahulu's Avatar Topic Author
Oil Pan O-Ring
11 Aug 2011 14:16 - 11 Aug 2011 14:25
#468397
Well I fixed a problem with my stuck drain bolt here . When I finished up, I noticed there were two o-rings on the old oil filter cover instead of one.
At first I thought the previous owner might have used two o-rings to seal it. Thinking about it more, I realized the o-ring between the drain pan and the crankcase may have fallen out. These two rings are slightly different size so I'm thinking that's what happened.
Just wondering if this o-ring is necessary? I haven't put new oil in the crankcase yet and can drop the pan again. It's just a pain and very messy.
Any thoughts? Here's a picture to help. I think #8 fell out. #13 is the o-ring that goes around the oil filter cover.
2strokeworld.com
Last edit: 11 Aug 2011 14:25 by Kapahulu.
  • DFryatt
  • DFryatt's Avatar
  • I'm an experienced wrench; new to the KZ world.
Re: Oil Pan O-Ring
11 Aug 2011 14:46
#468407
I just replaced the oil pan gasket on my 80' KZ750 two nights ago and I did NOT have an o-ring around the oil filter hole between the crank case and oil pan.
I actually wondered myself if there should be a gasket or o-ring in there but not having removed one from the pan initially, I did not install one.
Perhaps there was one at some point during this bikes life but I'm pretty sure i'm the first one to crack open the oil pan on her.
-Dan
80' KZ750LTD H1
  • Kawboy74
  • Kawboy74's Avatar
Re: Oil Pan O-Ring
12 Aug 2011 01:38
#468547
The o-ring in question could only have fallen out if you had the oil pan off. I had trouble keeping it in place when I put my pan back on so I used a little bit of glue on several areas of the groove to locate it during assembly. You do need to have it in place.
David
1974 Z1A As original as I could get it.
KZ1000 project done with tweaks to follow.
Burlington,Ontario,Canada
  • Kapahulu
Re: Oil Pan O-Ring
12 Aug 2011 04:15 - 12 Aug 2011 04:16
#468563
This afternoon I dropped the pan again and sure enough, the o-ring was not there. The extra ring I had leftover from the other day was a perfect fit. Mystery solved and now I won't be thinking about it.
2strokeworld.com
Last edit: 12 Aug 2011 04:16 by Kapahulu.
