I have a slight squeak at idle
  • djturnz
  • djturnz's Avatar Topic Author
10 Aug 2011 08:28
#468173
After riding home from work the other day, I pulled up to a stop sign and could hear a slight squeak. The only thing moving was the motor, the bike was completely stopped. It was in 1st gear with the clutch lever pulled in.
What could my new squeak be? It was similar to the belt on a car, but not as loud. Just a little squeak.
1982 KZ750 (4) LTD
  • Motor Head
  • Motor Head's Avatar
Re: I have a slight squeak at idle
10 Aug 2011 12:28
#468197
Possible Exhaust leak? Try putting a piese of hose to your ear, then try to track it down.
10 Aug 2011 16:03
#468227
Does it do it in neutral with the clutch lever released?
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
10 Aug 2011 18:20
#468238
I heard a slight squeak once, the oil pump was failing and not delivering oil to the top end sufficiently, and the "squeak" was the cam journals beginning to eat in the cam bearings
