Need torque specs. please!
- Goalieguy35
- JJ
09 Aug 2011 11:34
I need the torque setting on a 76 kz900 flywheel/rotor bolt. I have the specs for a kz 750 but id imagine the 900's are different.
Thanks
Thanks
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
- moneypit
- TeK9iNe
- What did you do!?!
Re: Need torque specs. please!
09 Aug 2011 22:32
Might want to verify against a manual... my KZ1000 is 90ft/lbs.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
09 Aug 2011 23:11 - 09 Aug 2011 23:11Yes.moneypit wrote: 18 ft pounds
FSM for Z1~KZ900
Dynamo rotor to crankshaft 18 ft-lbs
with KAWASAKI LIQUID LOCK-K (whatever that is)
FSM for 1977~79 KZ1000:
1977 16.5~19.5 ft-lbs with Locking Agent
1978 51~54 ft-lbs (no locking agent)
1979 94 ft-lbs (no locking agent)
Perhaps "Otto the Chemist"
Last edit: 09 Aug 2011 23:11 by Patton.
- bountyhunter
10 Aug 2011 02:50
surprising it could be that low. On my 750 twin it was something like 80 ft-lbs or more which is just about as tight as I could crank it.
- wireman
Re: Internet Employment
20 Aug 2011 03:58:blink: do they have any job openings for a rotor/flywheel bolt installer/torquer for a kz900? :woohoo:jimmypqauy wrote: Online Jobs - Hey, thought I would share this, if your searching for Online Employment. The supurb opportunity is Internet Employment .
And, Online Jobs .
- jonnybravo
- Banned
20 Aug 2011 05:42spammer bitch. why dont u give us a blow jobjimmypqauy wrote: Online Jobs - Hey, thought I would share this, if your searching for Online Employment. The supurb opportunity is Internet Employment .
And, Online Jobs .
- garyprather
21 Aug 2011 23:47
I use loctite all the time at work. I would use the green its for slip fit sleeves and such. Still good with heat resist . I have used all the colors, red which is for threads but green is the best hold. Just from my exp.
- wireman
21 Aug 2011 23:52
isnt green the one that works its way around threads that are already assembled?
ive always had good luck with blue loc tite myself,i save the red for dooms day projects and john deere tractors! :laugh:
- mtbspeedfreak
22 Aug 2011 00:01
Yeah, red is the more permanent of the three, blue can be removed and green is for penetrating existing fasteners.
2000 ZRX 1100
1976 KZ 900- Daily Driver
