Tach wire mounting hole plug
  • oldschoolbobber
  • oldschoolbobber's Avatar Topic Author
08 Aug 2011 02:57
#467646
Anybody have any ideas, or have already done so, in capping/plugging up the mounting location for the tach wire? I have a bobber so, there aren't any guages equiped on the bike. Here's a pic of what it looks like:
79 KZ750 Betty the backyard bobber
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: Tach wire mounting hole plug
08 Aug 2011 11:18
#467688
I'd clean the hole out with alcohol and find some kind of rubber stopper to glue and screw in there, or course drilling a hole in the end of it to accomodste the cable drive. Then maybe cut it flush.
I wouldn't use carb cleaner because it might ruin the existing seal which looks to be leaking already.
Another way would be to clean the hole out, put car wax on the cable drive, then fill the hole with a good sealer. Pematex Right Stuff would work for that. But you'd want to let it set a few days before you fired it up.
  • TexasKZ
  • TexasKZ's Avatar
08 Aug 2011 12:39
#467700
The following user(s) said Thank You: kwaker
08 Aug 2011 16:53
#467752
Hello, oldschoolbobber, and WELCOME to KZr! :cheer:
Including information about bike year and model may elicit better responses.
And it's easy to put the information in your signature where it will automatically appear in posted messages.
When done, the signature information appears in all posts, past and future. :cheer:
And may be changed as often as desired.
Attachment addsig.jpg not found
Good Fortune! :)
  • oldschoolbobber
08 Aug 2011 18:31 - 08 Aug 2011 18:33
#467778
Thanks for the responses guys. Sorry I forgot to mention the bike information, 79 KZ750.
TexasKZ...will that plug you linked, fit my bike. I see that it's for a kz900? I also updated my signature to show the appropriate information. Thanks for the post on how to set that up.
Thanks again guys,
oldschoolbobber
Last edit: 08 Aug 2011 18:33 by oldschoolbobber.
  • MFolks
  • MFolks's Avatar
08 Aug 2011 18:37
#467781
Maybe a freeze plug from the auto parts store will work, they come in many sizes.
09 Aug 2011 01:29 - 09 Aug 2011 01:35
#467917
This post is for reference to show info from kawasaki.com.
Could be mistaken, but there seem to be female threads in the cylinder head where male-threaded end of tach cable screws into against the #6 gasket.
Can't tell from the photo whether #6 and #7 are missing, or what holds #8 in position without the cable being attached.
6 92065-103 GASKET,TACHOMETER GER 1
7 92050-075 OIL SEAL 1
8 92087-009 GUIDE,TACHOMETER GEAR 1
9 670B1510 "O"RING 10MM 1
10 13223-013 GEAR,TACHOMETER
Good Fortune! :)
Last edit: 09 Aug 2011 01:35 by Patton.
