Loud POP at ignition.
- uncledirt
29 Jul 2011 14:52
The last few times I've gotten to the bike it won't start. Got all the right lights, etc, normal. Figured I wasn't getting gas, so I pull the tank, get a vacuum, play around and get gas into the carbs. Won't start. Twice now, when I put it up on the center stand and about to get the voltmeter, I see that my ignition switch is a little off to the right, and it's very easy to bump it to turn off the bike. So I turn it a little more to the right to see how far I can turn it and POP!!!!! comming from the pipe. Last time I figured no big deal, once in a year type thing. It just did it again at the gas station. Put it up on the stand, checked the 20 amp fuse. Put a new one in just in case. Remembered to turn it farther to the right, POP!!! Rode it home. I sounds exactly like a very short but quick backfire. But there's no combustion/compression at the time this happens? I spent 20 minutes trying to get it to start this last time. Is the ignition connection not connected well enough. Never dealt with that issue. Seems like I get plenty off spark when I turn it there. But to get a POP that loud w/o blowing a fuse? Don't know. Too afraid to ride far from home. And I lost 2 cyclinders on the way back. Has to be a ground I think? Can't get over the POP though...it POPPED so hard it knocked my shades off the seat.
77 KZ650 'C'
Bachelors know more about women than married men; if they didn't they'd be married too.
- loudhvx
Re: Loud POP at ignition.
29 Jul 2011 15:07
Do you have a Dyna S ignition?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- steell
29 Jul 2011 16:05
To elaborate on Lou's post, that loud pop is the spark plug igniting the mixture in a cylinder with an open valve, The reason the spark plug is sparking is because you turned the switch far enough to cause it to cut the power to the coil(s), and either the points are closed, or you have a Dyna S.
If you had the factory Kawasaki electronic ignition, I don't believe that would happen (according to my electron pusher friend Lou anyway)
- TeK9iNe
- What did you do!?!
29 Jul 2011 17:04
Yup that sounds like the culprit...
If you're losing a couple cylinders, might be wise to take her off the road for a few hours and go about the electrical contacts - cleaning and crimping them so they fit together nice and snug.
Pull teh control pods apart and clean em' up too, makes a big difference.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- uncledirt
29 Jul 2011 20:04
Dyna S, correct. The pods? You mean the 1-4 2-3 magnets on the metal face? I'm thinking I need to do just what you guys are saying, thorough electronic sweep and cleaning. How do you propose the cleaning be done exactly? Alcohol, degreaser type deal?
77 KZ650 'C'
29 Jul 2011 21:54 - 29 Jul 2011 21:55
"Pods" refers to individual air filters, one per carb.
Our resident electron guru prefers De-oxit to clean electrical connectors. It is available and Radio Shack and elsewhere.
Last edit: 29 Jul 2011 21:55 by TexasKZ.
- TeK9iNe
30 Jul 2011 15:01
I meant control pods, as in the handlebar control pods. With your kill/start switch, headlights, etc.
Open them up and spray all the contacts with electrical cleaner.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
