PLEASE HELP!! 1980KZ1000
- rockabillybobber420
29 Jul 2011 00:53
Hey everyone or anyone, quick question.My Kawi:
1980 KZ1000 E2 shaft
I am in the middle of replacing my head gaskets due to an annoying oil leak comming from where the head meets the block. I have disasembled the motor and cleaned off the old gaskets and prepped the surfaces. In my clymer manual it says to remove the tachometer drive gear before re-installing the cams. My problem is that the threadin plug that holds in the grive gear in, has about 1/4in' for the socket to grab onto. Because of a dumb moment I have basically knocked of the corners of the nut using a 21mm instead of a 20mm. My question is, do I have to remove the tach drive gear to reinstall the cams or can i just turn it until it lines up with the gearing on the cam shaft? Any help will be greatly appreciated!
Thanks again
Thanks again
Re: PLEASE HELP!! 1980KZ1000
29 Jul 2011 15:29
Don't know about re-installation, but as long as the thing is apart, now might be a prime moment to repair it.
- RonKZ650
29 Jul 2011 15:39
There's no need to ever remove the tach gear. No need to worry about lining up it's gear with the cam either. Bolt in your cams timed correctly and you're all done. Some may disaggree, but that's my 300,000 mile experience.
- riverroad
- 1980 1000LTD B4
29 Jul 2011 15:59
Yeah, I wouldn't take that out unless the o ring was leaking. I just took mine out yesterday. But it's not threaded. It's held in by a allen bolt that holds two pieces of contoured plate against the gear holder. Tkae them off and you should be able to work it loose. If not, spry it from inside and outside with a penetrating fluid and let it soak for a while. If that don't loosen it up, heat the area around it with a propane torch. And use a six point socket instead of a twelve.
