Head Breather Valve
- 79KZ1000LTD
Head Breather Valve
22 Jul 2011 09:38
Alright, I've got a 79 KZ1000 and I'm doing a bunch of work to it. One of the things I'm doing is I've cut the air box out (I know I know, I really hope I don't regret it), putting pod filters on. I've rejetted the carbs and I've installed a filter on the oil cooler. My question is this, what in the heck am I supposed to do with this? This hose went to the air box and I'm assuming I could remove this hose and put a breather filter in it's place but I can't seem to find one.
- riverroad
- 1980 1000LTD B4
Re: Head Breather Valve
22 Jul 2011 10:00
I threw that5 thing in the trash, and connected the two valve cover nipples with a piece of black garden hose. Fit perfectly. I never did put anything on the breather nipple. I know I should, but I've just been running without anything at all on it. But I think I saw a small filter that might fit on it at Auto Zone,
The only time I ever regret not having my air box is when I run through heavy cross winds at highway speeds, and heavy downpours. Misses a little. Not a big deal to me.
22 Jul 2011 11:07 - 22 Jul 2011 11:0779KZ1000LTD wrote: Alright, I've got a 79 KZ1000 and I'm doing a bunch of work to it. One of the things I'm doing is I've cut the air box out (I know I know, I really hope I don't regret it), putting pod filters on......
Cut the airbox out? As the General told the new test pilot "You don't need no stinkin' parachute; what could possibly go wrong?" :laugh:
Last edit: 22 Jul 2011 11:07 by 650ed.
- JR
22 Jul 2011 15:35
From Z1Enterprises
Type breather in their search box
- 79KZ1000LTD
22 Jul 2011 21:32
Found this at the local parts store and just modified the old hose around it. Lines up perfect.
- JR
22 Jul 2011 22:43
Sorry.
My mistake. I thought you were looking for a crankcase breather to replace the hose from crankcase to airbox. We never had that anti smog tubing stuff up here in Canada but I hear you can just run a straight hose from one side to the other or you can purchase block off plates .... from APE?
- MFolks
22 Jul 2011 22:59
Smog Block Off Plates
www.tpoparts.com (A nice kit, comes with instructions, & vinyl caps for vacuum lines)
www.kzzone.com/billet.html (They were working on block off plates foe the smaller 4's last I heard).
- riverroad
- 1980 1000LTD B4
23 Jul 2011 08:45
79KZ, you really don't need that smog valve. All you need is either a piece of hose connecting the two nipples, or some block off plates. Then just adapt your breather filter to your breather.
