Snapped the clutch cable... KZ440 LTD
- LewisKZ
21 Jul 2011 21:22
So i snapped the clutch cable up by the lever, as you can see by the pictures. I consider myself handy, but im self admitted to know nothing about cars and im learning about bikes as i fix them. Is this just as easy as ordering a new cable, snaking it through where the cable routes now and hooking it up to the clutch release thing?
www.z1enterprises.com/Cable--Clutch--KZ400-KZ440-1458.aspx
I have stock handlebars, if i order this one above will it be perfect? It looks to me it comes with the housing and all that crap, so do i need lube or anything else for this (probably) easy fix? Any help for this newb is godly appreciated!
Attachment IMG_20110721_195321.jpg not found
Attachment IMG_20110721_195349.jpg not found
Attachment IMG_20110721_195445.jpg not found
1981 KZ440 LTD D2
1981 KZ440 LTD D2
- LewisKZ
Re: Snapped the clutch cable... KZ440 LTD
21 Jul 2011 21:37
The more i read it looks like i def should buy the little lube tool and a can of lube. This doesnt look too hard at all, i just hope the Z1E clutch cable is the right stock length.
1981 KZ440 LTD D2
1981 KZ440 LTD D2
- Vter Bob
21 Jul 2011 21:55 - 21 Jul 2011 22:00
Routing the cable and attaching both ends PROPERLY is about 80% of the job. You will then need to do a clutch cable adjustment. Do you have an FSM or aftermarket service manual? I'm not real familiar with the 440 but if it's similar to the 550 it's pretty straightforward. There is an adjustment midway on the cable and another right on the lever perch. You might find a link to a downloadable FSM in the file base here.
PS: Yes, a cable lube tool is handy device to have. You should pay attention to where the "Barrel" on the end of the cable fits into the lever. Check for burr's and remove, lube this area with a heavy grease. From your pics it looks like this is exactly where your cable failed.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
Last edit: 21 Jul 2011 22:00 by Vter Bob.
Last edit: 15 Feb 2013 11:24 by martin_csr.
- MDawnz1
22 Jul 2011 01:42
Everything the other folks said is all good info.
I can't remember ever doing a cable on a 440 ,,but ,,
Don't forget to back off the adjuster on the bottom before installing the new one.
While you have the cover off make sure the parts down there are clean and lubed .
Lots of chain crud can build up down there .
AND ,,,when you adjust it , start from the bottom ,then the middle (if you have one)
Then the top,at the lever .
Don't forget to take off the lever and clean and lube the pivot .
1974 Z1a, still 903
- LewisKZ
26 Jul 2011 10:15Vter Bob wrote: Do you have an FSM or aftermarket service manual?
Yeah i have a Haynes, but strangely i dont see anything about this fix in it. Regardless i think it looks pretty easy (famous last words), i got my new cable and am going to work on it tonight. Thanks again for all the tips.
1981 KZ440 LTD D2
1981 KZ440 LTD D2
Last edit: 15 Feb 2013 11:03 by martin_csr.
- LewisKZ
26 Jul 2011 18:01
I havnt done an adjustment before, but i found the OM scans online that should help.
www.kz400.com/KZ440MaintainanceFrameset.html
1981 KZ440 LTD D2
1981 KZ440 LTD D2
- MFolks
26 Jul 2011 18:15
This procedure might help (written for the bigger 4's)
Clutch Cable Replacement On Some Kawasaki Motorcycles
With Proper Mechanism Adjustments
1.About mid way down the clutch cable is an adjuster; shorten the cable as much as possible.
2.Remove the small cover on the left side of the sprocket cover and loosen up the lock nut on the clutch throw out mechanism.
3.Remove the shifter lever; the sprocket cover, and lay the cover on some rags or news papers.
4.Have on hand a small cotter pin that will be needed to prevent the new clutch cable from coming out of the throw out mechanism.
5.At the left handlebar turn in the slack adjusters for the clutch cable and then take out the pivot bolt.
6.New clutch cables may or may not have lubrication; now's the time to either hang the new cable up overnight so heavy oil can flow through it or buy a cable luber kit with the special clamp and can of spray lube.
7.Attach the cable to the cover's throw out mechanism and secure it with a new cotter pin.
8. While you're in there, check the wiring from the alternator(YELLOW WIRES, or any wires from the alternator), remove the excess chain lube from the clutch push rod and check the wire routing that goes above the engine sprocket.
9. Check the lock washer for cracks on the engine sprocket and any "Hooking" of the sprocket teeth.
10 Route the clutch cable the same way the old one was and connect the cable to the clutch lever; and the pivot bolt gets re-installed.
11.Carefully install the sprocket cover, making sure the push rod is engaged(in the adjustment mechanism) and then tighten up the cover.
12.Adjusting the clutch play and cable tension is real easy; using a flat bladed screwdriver, turn the slotted screw clockwise(to the right) until it becomes hard to turn; then turn it counterclockwise(to the left) 1/4 turn and tighten the lock nut. On some Kawasaki’s, the adjustment will turn the opposite way, so keep this in mind.
13.The mid way cable adjuster and lever slack adjuster may need to be adjusted for correct cable slack.
14.My factory shop manual lists 2-3mm as the correct play in the lever after the cable has been properly tensioned.
15.Re-install the covers, and shifter lever, start the engine to check the shifting action.
16.These engines have a shifting lock out to prevent moving in any gear higher than second unless the engine is running and proper shifting is done.
- LewisKZ
27 Jul 2011 15:31
I did it last night and it was pretty easy. After a ride, i found there is too much play in the lever though, so i will need to adjust the cable at the mid way point more. I want to keep the adjuster at the lever in its proper 5-6mm position.
The twins much be much different. I didnt have to do anything to the left side of the bike... remove sprocket cover and stuff? The engine end of the cable on the 440 was located on the right hand side of the bike and connected just fine without having to remove any foot pegs or covers.
So yeah, good stuff. My bike was only out of commission for 5 or 6 days.
1981 KZ440 LTD D2
1981 KZ440 LTD D2
27 Jul 2011 16:33 - 27 Jul 2011 16:34
Yes, there is one more adjustment. The first adjustment to make is on that lever that the cable hooks to on the engine. Here's a pic (maybe) See #38 an 92009
Last edit: 27 Jul 2011 16:34 by TexasKZ.
