Identify this please
- mstbone67a
10 May 2006 02:57
While looking at z1enterprise site noticed there is a o-ring for the kz1000 on the cylinder head.
Where does this go?
Cylinder Head O-Ring Kawasaki
KL16-5639
K&L
OEM: 92055-1148
Cylinder Head O-Ring - Fits Kawasaki KZ1000J/K/M/R/P KZ1100A1/A2/A3/B1/B2/D1/D2/L1
link
Where does this go?
KL16-5639
K&L
OEM: 92055-1148
link
- JMKZHI
Last edit: 03 Dec 2008 19:22 by JMKZHI.
- craigpuckett
Re: Identify this please
10 May 2006 06:47
the only "O" rings that I know of that goes on the J head are the 4 that goes between the block and head on the outer studs to seal the oil passages and the one oblong one that goes between the head and the block that seals the cam chain gally.
I hope this helps
I hope this helps
- ejshotgun
10 May 2006 07:14
On my model it shows an O-ring between the cylinder base gasket and the cylinder head.But the part number is... 92055-054(size-"O" RING,73MM) (I think that is what Craigpuckett was saying)
Here's the link to Kawasaki
Post edited by: ejshotgun, at: 2006/05/10 10:18
- brianrae33
10 May 2006 08:30
there is an o ring around the cam chain galley...it can be avoided by using a one piece head gasket from any of the numerous online sites....also there are four large o rings that go around the cylinder sleeves...only o rings i know about..
1982 kz1000ltd
- Mcdroid
- Gone Kwackers
10 May 2006 10:11
The part number refers to an itty bitty o-ring that goes on the knock-pins of later model (J) jugs.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mstbone67a
11 May 2006 11:50
My concern was that I did not see that o-ring when I removed my head on my kz1000k ltd.
On the kaw site it didnt not show the oring for my model.
thanks
thanks
- Mcdroid
- Gone Kwackers
11 May 2006 12:03
mstbone67a wrote:
Look under cylinder/pistons on the exploded diagrams...the part is figured.
It may go on the outer studs, I don't know, but four are required.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- kzbikeman
11 May 2006 13:36
I just rebuilt the top end of my 1981 J model. Four O-rings are required for the outer oil galleys between the head and cylinders. They are easy to miss as the stick to one or the other on removal. Don't buy them through Kawasaki! ($7.92 each!) I found a connection in Seattle that sent me a sample pack of viton orings and I am using them. The viton material is more resistant to heat. After 200 miles I still have no leaks. When I get home today I will post the dimensions. I will order a pack later (about $6.00 for 50!).
After 25 years the o-rings are wasted and not in the Vesrah gasket kit.
