Pod air filters
  • silverado
  • silverado's Avatar Topic Author
Pod air filters
13 Jul 2011 23:54
#462749
I've been putting a 550ltd together for awhile. I searched pods and saw alot of pros and cons. One quote was something like if Kawasaki couple spend 10 bucks on pods why would they build and research the airbox. I've had my airbox off for weeks and driving the bike around the parking lot at my shop, cleaning carbs daily,(it sat for 15 years). other than cleaning i haven't touched any adjustments. Tonight I cursed and swore and finally got the airbox back in, installed the filter and took it for a ride, what a difference. So from what I've read, pods/airbox, I'll keep my airbox.
1980 kz 650 f
2 1981 kz550 ltd's
1 19?? kz750
  • loudhvx
  • loudhvx's Avatar
Re: Pod air filters
14 Jul 2011 03:13
#462776
Are you comparing open carbs against airbox, using the same jetting for both?
  • silverado
Re: Pod air filters
14 Jul 2011 08:01
#462786
Yes it had open carbs.Too much work to get the carbs on and off until I got all the crap cleaned out of them.
1980 kz 650 f
2 1981 kz550 ltd's
1 19?? kz750
  • martin_csr
  • martin_csr's Avatar
Re: -
14 Jul 2011 08:43 - 15 Feb 2013 10:44
#462789
Last edit: 15 Feb 2013 10:44 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
Re: Pod air filters
14 Jul 2011 12:34 - 14 Jul 2011 12:37
#462816
I have 2 1981 KZ550's. One with pods and one with airbox. Both with similar Kerker style exhausts. The jetting is very different on the bikes. When jetted properly, they both run very smooth and powerful. The airbox has more pickup from a stop, but the pods have more top end rush on the highway.
I'm not saying one would be faster than the other in a drag race, because it's hard to say. But the airbox is more frun from light to light in the city, but the pods are more fun on the highway.
But neither would run well with the jetting from the other. The early KZ550's, which use the mechanical-slide tk-22 carbs, respond well to pods. (All as Martin_CSR said.)
I use both, and see advantages to both and downsides to both. If you don't mind the airbox hassles, I say keep it on, for sure. Either way, I never recommend anyone throw away the airbox. Always store it or sell it. Someone somewhere will want it.
Anyway, here is some tk-22 info you may want:
home.comcast.net/~loudgpz/GPZweb/TK22mainPage/TK22mainPage.html
Last edit: 14 Jul 2011 12:37 by loudhvx.
  • TexasKZ
  • TexasKZ's Avatar
Re: Pod air filters
14 Jul 2011 12:38
#462818
Several guys over at ZRXOA have experimented with a variety of intake configurations. The one that produced the most power on the dyno was a slightly modded stock air box with a high-flow filter, even with a fairly well-modded engine. The difference would likely be even bigger in the real world when one factors in the turbulence around the outer two pods that will not be the case inside a box.
  • loudhvx
  • loudhvx's Avatar
Re: Pod air filters
14 Jul 2011 13:23 - 14 Jul 2011 13:27
#462822
I think modern airboxes are much better designed than the ones on the 550's. I wouldn't go cutting or drilling an airbox as that would make it difficult to go back to stock.
I'm not even sure the goal with pods is only to go faster. For me, part of it was to clear out some of the clutter for looks and easier maintenance. But on the highway, the pod rush is pretty addicting.
As seen on the wideband, the only time side drafts had a discernable affect was when cruising at very small throttle openings. That is when the carbs are at their leanest. If you were to compensate, even a little bit, and jet them slightly richer on the pilot or needle, you wouldn't really feel the difference, but you may lose a couple miles-per-gallon... not much of a problem for me since I was getting in the 50 mpg range.
(Incidently, there was no noticable difference on the outside two cyclinders when checking the plugs, but that is not a very precise measure.)
Last edit: 14 Jul 2011 13:27 by loudhvx.
  • DoubleDub
  • DoubleDub's Avatar
Re: Pod air filters
14 Jul 2011 15:25
#462839
Always great to see someone posting info with data to back it up - thanks Loudhvx!
  • uncledirt
  • uncledirt's Avatar
Re: Pod air filters
16 Jul 2011 22:58
#463240
Yeah, it didn't take long for me to figure Loud is pretty much Yoda on many subjects either.
I have also been led down the pod road many times by buddies who are old racers from the 80's and know EVERYTHING it seems. But, there is a lot about that engineering quote. Yes, it's designed for a reason and a good one. I too would like to make room in that area, and I like the looks of the pods but I just hate spending time fixing things that used to work perfectly in the 1st place. And I've heard a lot about the pains after doing it (remember, 4 carbs, 4 headaches). Loud, you reminded me of something interesting before I started blabbing. Your info on pods being better on highway vs. the non pod intown KZ. I was thinkin about the 4 ohm plugs I have on my(650 modelC). At higher RPM and speeds I should actually benefit from that shouldn't I. Lower speeds are less wristy, at higher speeds I can depend on better electrical flow?
77 KZ650 'C'
Bachelors know more about women than married men; if they didn't they'd be married too.
  • loudhvx
  • loudhvx's Avatar
Re: Pod air filters
17 Jul 2011 00:44 - 17 Jul 2011 03:06
#463268
First of all, Thanks mucho for the really kind words! :)
And yes, if really simple, cheap addons could produce a bunch of power, the factory would use it. However, let's keep in mind, a lot of what the factory does is not what the engineers would prefer to do. The air-injection system is costly and adds no power. Stock exhaust is expensive, heavy and reduces power. You could probably make a cheaper one that makes more power.
A lot of what the factory does is decided by the government, not the engineers looking for power.
I think you mean 4 ohm coil?
Coil selection is more about matching the dwell to the coil (or matching the coil to the dwell). Slower coils, meaning coils with higher inductance values, tend to have higher resistance values. If the coil takes longer to charge, you need to give it more dwell in order for it to accumulate enough energy to provide adequate spark.
Since the Dyna S gives about as much dwell as is possible, you don't really need a fast coil at all. Much of the excess dwell is just burned away as heat inside the coil. So yes, the 4-ohm coil will save you electrical power over a 3-ohm coil. It will save electrical power at all RPMs, most likely. It will also reduce the heat dissipation in the Dyna S, which is a good thing.
People often mistake "hotter" coils as somehow providing more spark energy. That is only true under certain circumstances. If the dwell is adequate, then most likely, the 4 ohm coil will deliver more spark energy. This is because the 4 ohm coil will have more inductance, which is part of the energy equation.
Last edit: 17 Jul 2011 03:06 by loudhvx.
  • ELCouz
  • ELCouz's Avatar
Re: Pod air filters
17 Jul 2011 02:38 - 17 Jul 2011 02:39
#463289
If you go the pods way, which god forbid you... you will be cursed... FOR LIFE!! :silly: :lol:
Hope this helps :P
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 17 Jul 2011 02:39 by ELCouz.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Pod air filters
17 Jul 2011 11:58
#463331
Lou D. is THE MAN! :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
