Clutch dropping from 2nd to neutral
- Mandyrew
13 Jul 2011 18:33 - 13 Jul 2011 18:34
Hello. Had a long drama with a stripped oil drain and had to put the bike on it's side to do the drilling, it all worked out, finally. Take her on the first ride and for the first time the bike often slips from 2nd to neutral when the throttles on... Sometimes it goes to 2nd, and if I quick take it to 3rd I'm okay there.
Anybody have a quick diagnostic idea about why this would happen after the bike was put on it's side?
Thanks!
Thanks!
KZ440 LTD '81
Last edit: 13 Jul 2011 18:34 by Mandyrew. Reason: Added detail
Re: Clutch dropping from 2nd to neutral
13 Jul 2011 18:41
Could it be a bent shift fork preventing 2nd gear from being fully engaged? Just guessing; I have had no similar experience. Ed
- etbike3135
13 Jul 2011 19:13
If the bike shifts into second and you can ride there with light throttle and when you gas it more then it slips or pops out its a worn second gear in your transmission.
1973 Kawasaki Z1
18 years in dragbikes
- Kawasaki_Mike
- 1980 Kawasaki 750 LTD
15 Jul 2011 21:25
I had kind of the same problem with my bike. Turned out I wasn't completely kicking it into 2nd and it would slip back into neutral. Could be the same issue.
15 Jul 2011 21:30
When this starts on a bike that did not suffer so before, it is generally a bent shift fork or rounded off engagement dogs on the gear. However, is it possible that any shavings got into the tranny from the drilling episode? Really, it isn't difficult to remove the pan to prevent that and the gasket is pretty cheap.
- Mandyrew
16 Jul 2011 12:32 - 16 Jul 2011 14:46
I really like the shards in the transmission theory ... something that connects the slippage to the previous procedure makes the most sense ... i've had no time this week to work on it but i'll be getting in there soon.
don't quite understand though how a shard could get through the filter, though ...
...and also, these 81 Kz's don't have an oil pan, it's all in the block ...
KZ440 LTD '81
Last edit: 16 Jul 2011 14:46 by Mandyrew. Reason: added detail
