SOB - SOT - SUB
SOB - SOT - SUB
02 Jul 2011 17:36 - 02 Jul 2011 17:38
When describing valve shim location, have noticed that "SOB" is sometimes intended as "Shim-On-Bottom," perhaps interchangeably with "SUB" for "Shim-Under-Bucket," but is at other times intended as "Shim-Over-Bucket," perhaps interchangeably with "SOT" for Shim-On-Top.
On a stock KZ1000, the shims are located between the cam and bucket, where cams touch shims without touching buckets. On various other models, cams touch buckets without touching shims.
In a recent thread, racer54 asks about maximum lift in a stock KZ1000 before needing to go to SOB valve gear, where SOB is interpreted to mean Shim-On-Bottom, which interpretation APE Jay adopts in explaining how a taller cam may cause the shim to tilt with shim on top.
Am guessing this means that the correct acronyms are either SOB for Shim-On-Bottom or SOT for Shim-On-Top, and that it's incorrect or a misnomer to use SOB as meaning Shim-Over-Bucket.
And SUB is mostly for firing torpedoes. :lol:
Last edit: 02 Jul 2011 17:38 by Patton.
- bountyhunter
Re: SOB - SOT - SUB
02 Jul 2011 18:54
I thought SOB was shim over bucket. maybe we should just go with "over" and "under".
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: SOB - SOT - SUB
02 Jul 2011 19:16
SOB = shim over bucket to me, or someone I don't like very well... :evil:
This is why I hate acronyms, too many overlaps in meanings depending on where you live, work, etc.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- racer54
Re: SOB - SOT - SUB
02 Jul 2011 19:18
I always took it as being... S.O.T was shim on top ...and S.O.B...was shim on bottom!
- APE Jay
Re: SOB - SOT - SUB
02 Jul 2011 21:00racer54 wrote: I always took it as being... S.O.T was shim on top ...and S.O.B...was shim on bottom!
That's the way it has always been. However, I just realized that sob could be interpreted to be shim over bucket. Never heard that before.
- zed1015
Re: SOB - SOT - SUB
03 Jul 2011 07:22
You guys like to make things complicated don't you ? :laugh:
Over here it's always been -
S,O,B = Shim over bucket
And
S,U,B = Shim under bucket.
'S' and 'B' being the correct constants for the subject matter
And
- loudhvx
Re: SOB - SOT - SUB
03 Jul 2011 12:34
That's why I've always spelled it out. Seen it confused too many times.
I've always seen them described as shim-over-buckets, in magazines, etc., but never seen "SOB" used as an abbreviation for shim-over-buckets, only shim-on-bottom. Obviously, it's easy to see why people would come to the wrong conclusion.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Old Man Rock
Re: SOB - SOT - SUB
03 Jul 2011 12:40
I for one... like NADs have removed the shims and welded in the bucket spacing.... No shims to worry about that way.... :blink:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
