slight chain noise
- 82KZ305Belt
slight chain noise
24 Jun 2011 10:40
I've no ridden my bike a couple hundred miles since converting it to chain, but I'm not used to chains so I dont know whats normal what isnt. It seems to work just fine, and I have it tensioned according to the service manual.
The only issue, and I'm not even sure it is an issue, is that I hear a slight ticking sound in higher gears when I let off off the throttle to change gears. Sounds like chain hitting something, but I have looked and find no evidence of it hitting anything. Thanks t0 work and crummy weather I still havent been able to ride the 70m mile round trip to the nearest real bike mechanic to have him look it over. I'm not sure this sound is anything to worry about, but since I'm a worrier it worrys me just a little bit. Is it normal for a chain to make a little noise when you ease off to shift in higher gears?
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
- ELCouz
Re: slight chain noise
26 Jun 2011 14:40
All motorcycle chains have some «slack» since your bike wasn't designed for chain use maybe its lacking of a «chain rubber damper» around the frame causing the chain to hit the frame during slack release...
just a thought..
regards,
laurent
just a thought..
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
- 82KZ305Belt
02 Jul 2011 16:39
Whats a chain rubber damper? Not coming up with much except cam chain rubber damper.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
03 Jul 2011 00:37
For sure your chain should not be hitting anything. Please describe how you adjusted the chain. Ed
- hypnohio
03 Jul 2011 07:37
my '82 440 had been converted to a chain drive and the chain was hitting the front bracket holding on the belt guard.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
2003 EN500 C
2006 Virago 250
- 82KZ305Belt
03 Jul 2011 14:53
I can find no evidence the chain is hitting anything, and I've looked several times. I cleared everything out of the way before I installed it. I am wondering if it is making the noise on the sprocket.
I adjusted the chain following the service manual directions for chain drive 305s, with the bike on center stand I gave it 25-30 mm slack halfway between sprockets.
I have to say thats a hard thing to measure accurately but I've done it after almost every ride since I converted. Part of the frame is right in front of the chain at the halfway point, so I cant get a level view at it. And various other things like mufflers get in the way of a clear, level view too. Nevertheless I believe I have it in that 25-30 range.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
03 Jul 2011 15:37
Perhaps drive chain isn't perfectly aligned.
True test is exact equal distance on both sides between center point of swing arm pivot bolt and center point of rear axle.
- 82KZ305Belt
03 Jul 2011 16:03
Perhaps...I've heard that method can be a little off too though, if the swing arm bushings are a little off. Something to keep in mind though, I will take a look at it and see if gives me a different answer.
But now it seems something else is going on. On my morning ride I started to hear a louder noise. While I was riding it occured to me that the original noise might just be the front sprocket cover rattling, because I only have 2 screws holding it on. So I inspected the frame, chain, and eveything once again and found no evidence of rubbing, and put the cover on with all 4 screws. I didnt hear noise #1 but the more serious noise #2 is still there. And now I'm starting to wonder if it might be cam chain noise, not drive chain. It still sounds like a noise that a chain MIGHT make, eg something moving is hitting something else. This noise comes a fraction earlier than noise #1 did, just as I reach peak rpms in a gear and just BEFORE I ease off to shift. Is the behavior of this noise consistent with cam chain noise?
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
03 Jul 2011 16:03
Chain adjustment sounds about right. Is it possible the chain is kissing the underside of the chainguard? If you lift the chain with your finger can you make it touch the chainguard? Ed
- 82KZ305Belt
03 Jul 2011 16:59
No, its not even near the chain guard. Check my avatar. If the drive chain is too anything its too tight, but I think its just the way it should be. Course thats based on all of several weeks experience with chain drive motorcycles, ie not very much.
I know sounds can telegraph but this sounds further forward too.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- 82KZ305Belt
Re: not so slight chain noise
04 Jul 2011 18:39
Well the noise is not so slight anymore. It sounds like a table saw hitting a nail at slow speed when it happens-ratatatatatatatatatatatat!!. I hear the new louder noise, which I believe is just a worsening of the old noise since I dont hear that anymore, constantly once it hits 4000 rpm. So that leaves me stuck at about 35mph and under.
I'd love to do the wheel alignment check with the swing arm measurement, but I dont see how. I see no way to take a straight line measure from front to back of swing arm, there are too many nuts bolts frames and fittings in the way. Even if I drop the mufflers there is undroppable stuff in the way.
Guess I'm going to have to buy that trailer I saw for $100, and haul it 35 miles to the nearest shop if I cant figure this out. Any other ideas??
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
04 Jul 2011 19:28
Assuming it's the chain touching something can you inspect the chain very carefully to see any telltale signs (prehaps a scrape, or other mark) that might help indicate whether it's the top, bottom, left, or right side of the chain that's making contact? If you could figure out which part of the chain is touching it might make it easier to find the spot on the bike that it's touching. Again, this all assumes it actually the chain making the noise. Ed
