first engine rebuild advise
- fstnv1
20 Jun 2011 17:17
Ok So Iam going to start in my first rebuild on a Bike motor Iam going with a 1200 kit maybe a little smaller Ive built a lot of drag car motors is it about the same thanks any advise will be used thanks
Re: first engine rebuild advise
20 Jun 2011 23:45 - 20 Jun 2011 23:47
If your drag car engines were inline 4, air-cooled and had press-fit roller bearing cranks and constant mesh trannies in the sump, it will be exactly the same.
Otherwise, it might be a good idea to pick up a factory shop manual for your particular engine and spend some serious time reading build threads on this site and getting friendly with old drag bike engine builders in your area. These old KZs have been raced for so long that there is a mountain of information on how to make them go fast and there are several good displacement/cam/carb/exhaust/tranny combos that will make fabulous starting points.
Last edit: 20 Jun 2011 23:47 by TexasKZ.
- wireman
21 Jun 2011 16:30
start with a solid bottem end,inspect/replace anything questionable and work your way up from there.
what are you planning on doing with the bike?
- KZ_Rage
- Kentucky Bourbon Barrel Ale
21 Jun 2011 18:34wireman wrote: start with a solid bottom end,inspect/replace anything questionable and work your way up from there.
Sounds like good advice for picking a girlfriend too! :whistle:
With your background is it safe to say you're going to use this bike on the strip exclusively?
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- fstnv1
21 Jun 2011 20:31
Iam going to ride it on the street and maybe a trip down the track once in a while
- cavanaughracing
21 Jun 2011 21:48KZ_Rage wrote:wireman wrote: start with a solid bottom end,inspect/replace anything questionable and work your way up from there.
:laugh:
Larry C.
cavanaughracing.com
cavanaughracing.com
