Specter 1100 oil cooler mod
  • grabenhexe
  • grabenhexe's Avatar Topic Author
19 Jun 2011 20:16
#458228
I am wondering if anyone has successfully installed an oil cooler on a kawasaki specter (spectre) 1100. I am interested in porting locations. If you could post any pics it would be appreciated.
thanks
  • MFolks
  • MFolks's Avatar
Re: Specter 1100 oil cooler mod
19 Jun 2011 21:48
#458242
  • grabenhexe
20 Jun 2011 19:20
#458395
Does anyone know where to port an oil cooler through a kawasaki 1100 engine? I know there is a return port to the rear of the 4th cylinder, but I don't know where to port from the engine into the cooler. thanks for any replies
  • MFolks
  • MFolks's Avatar
20 Jun 2011 19:42
#458396
The 1981,1982 GPz's have a factory oil cooler & I believe the ELR's did too. If you can locate a wrecked one, installing the oil cooler should be easy.
  • grabenhexe
20 Jun 2011 19:45
#458399
ok, i will have to go to the motorcycle graveyard and look around. thanks for the reply!
  • gengomerpyle
  • gengomerpyle's Avatar
20 Jun 2011 19:49
#458401
ive dealt with a guy in washington state that did have a cooler for sale from a 1982 gpz 750. ive bought a few things from him and hes a great guy to deal with. if you want his email addy let me know in an IM
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • hocbj23
  • hocbj23's Avatar
20 Jun 2011 19:55
#458404
The 1100s have an inlet/outlet fixture in the rear center of the engine.Get that part and u can run and outlet/inlet line from the same place.Thats what I did for my 82 CSr and ran the lines under the tank so u cant even see em.U can retain ur oil pressure lite this way as well.bj
