One Glowing header...
  • Thecreeper77
  • Thecreeper77's Avatar Topic Author
15 Jun 2011 15:00
#457427
So I Started my KZ up today and let it warm up a bit. It was idling at about 2-3K (known carb issues)and i noticed header #3 was glowing. I idled down and it stopped. Rode it around for less than 10 min and didn’t notice it again. What could be the issue here? I suspect that carb #3 is a bit lean?
Any advice or assistance would be appreciated.
1980 KZ1000
2008 Versys
  • bountyhunter
  • bountyhunter's Avatar
Re: One Glowing header...
15 Jun 2011 17:04
#457439
Probably running very lean on that cylinder.
  • MFolks
  • MFolks's Avatar
15 Jun 2011 18:25
#457455
Pull the sparkplug for that cylinder. If the center insulator is white, you're running far too lean and could melt the piston or damage the valves.
Check the ducting(boots) from the air filter box to the carb and between the carb and engine(carb holders) for signs of a vacuum leak. To determine where it might be, use a spray of WD-40,carb cleaner or an UNLIT propane torch on the rubber bits while the engine idles.
If the rpm goes up, you've found the leak. Also check the rubber sync ports for cracking as this could also be a source for leaks.
  • H1Vindicator
  • H1Vindicator's Avatar
15 Jun 2011 19:00 - 22 Jan 2013 00:58
#457464
Last edit: 22 Jan 2013 00:58 by H1Vindicator.
  • Thecreeper77
15 Jun 2011 21:13
#457497
Well, I’m gona take it to a shop to see if they can evaluate the motor for me. See what’s up and what other issues they can find. If there is damage to the motor(cylinder or valves) due to the lean mixture, is that fixable? If not, anyone need parts? :(
1980 KZ1000
2008 Versys
  • DoubleDub
  • DoubleDub's Avatar
15 Jun 2011 21:30 - 15 Jun 2011 21:31
#457503
It's more likely a carb issue causing the lean condition...or intake manifold leak causing extra air to be allowed into the chamber.
Last edit: 15 Jun 2011 21:31 by DoubleDub.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
15 Jun 2011 22:08 - 15 Jun 2011 22:09
#457511
Glowing? Never got one that hot but the evidence points to extremely lean. Does it always want to idle that high to stay running?
There is only one shop around here that might work on something as old as our bikes but the cost is crazy. I do all my own work and when I get too old to do that then I guess the bikes get sold.
Your bike is very fixable, don't get discouraged, just take a look at what mine looked like before I brought her back to life (that's gas and Indiana red clay, it ran but was spitting gas the whole 1/4 mile I rode it to be sure the trans was good).
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Last edit: 15 Jun 2011 22:09 by KZ_Rage.
  • martin_csr
  • martin_csr's Avatar
Re: -
16 Jun 2011 10:25 - 14 Feb 2013 11:23
#457594
Last edit: 14 Feb 2013 11:23 by martin_csr.
  • otakar
  • otakar's Avatar
16 Jun 2011 23:04
#457702
Talking about glowing headers. Watch this video.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • DoubleDub
16 Jun 2011 23:54
#457718
That can't be healthy.... :ohmy:
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
17 Jun 2011 03:21 - 17 Jun 2011 13:34
#457736
What a 'tard. I hope he throws a rod.
To clarify, I meant the guy in the video. I read through this thread this morning and many apologies if thecreeper77 took offense. :blink:
2000 ZRX 1100
1976 KZ 900- Daily Driver
Last edit: 17 Jun 2011 13:34 by mtbspeedfreak.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
17 Jun 2011 04:19 - 13 Feb 2012 18:24
#457738
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 18:24 by KZ250LTD.
